1994 corvette harmonic balancer HELP
Im, having a bad vibration that might be coming from what I guess if the crank shaft pulley is this also referred to as the harmonic balancer.
I think I have it on wrong if thats possible. I put is on by just lineing up the bolt holes nothing else. After putting it on I have been getting a bad vibration from the drive shaft area.
I need some serious help dont know what to do at this point.
The balancer can go on 3 ways by the bolt pattern. It should be put on in the same place it came off.
What work did you do on the car? Did you change the opti?
If the vibration is from the driveshaft area, why would you suspect the balancer?
I have been marking position for years. I was under the impression from others it could go on any way, although I probably never tried it, that I can remember.
If he beat on the outside of it that could have damaged it. But you might feel that without driving, just running the engine up.
The hub can be installed in any position because the crank is not keyed. The balancer cannot be installed in any position due to the reason I cited above.
I looked at it again and seen the arrow on the balancer and lined it up with the 3 armed metal part it attaches to which has an raised piece on it. I was told by the corvette dealer that this balancer has be be aliened or it will send a vibration right down the drive shaft. i will let you know how this turns out thank you all for you fast response this car is driving me crazy.
