high idle
Old Oct 19, 2009 | 01:37 PM
schimek3624's Avatar
schimek3624
Default high idle
I have a '95 corvette manual transmission. The idle on the car when first started runs at 1,500 rpm. After driving it for a half an hour or letting it idle until the coolant gets worm the idle will creep up to 2,100 rpm.
I check the hoses for vacuum leaks but can't find any.
Any suggestions as to what to try next?
Old Oct 19, 2009 | 04:07 PM
IslandPirate's Avatar
IslandPirate
re-check for Vacuum Leak(s)
TPS (Throttle Position Sensor ... on the Throttle Body)
IAC (Idle Air Control valve... does a '95 have one?)
I'm still trying to nail down a similar issue on a '90 ... no luck yet, I really think it's a vacuum leak somewhere that I just haven't been able to track down.
Old Oct 20, 2009 | 08:51 AM
Red 91's Avatar
Red 91
Are you sure your tach is accurate?
Old Oct 20, 2009 | 10:23 AM
schimek3624
Its accurate. I don't need to use the gas pedal to accelerate. I can literally accelerate in the first four gears without touching the gas pedal
Old Oct 22, 2009 | 05:45 PM
copper_94's Avatar
copper_94
under the right plenum there's a plastic tube running from the top of the engine to the throttle body aft of the iac. check it and both ends of it for cracks.
Old Oct 22, 2009 | 09:57 PM
89 Bob L's Avatar
89 Bob L
After checking for vacuum leaks, as stated above, clean the throttle body, using throttle body cleaner, not carb cleaner. Remove and clean the IAC and the area where the IAC enters. Pipe cleaners should help make the job easier. Did you check for any trouble codes? The O2 sensor?
To high idle
