Heater core flush questions
Old Oct 19, 2009 | 09:02 PM
pappy.72's Avatar
pappy.72
Default Heater core flush questions
Here is my problem. I have no heat in my 96 LT4. I have searched and found several posts about flushing the core and fixing the problem. I have checked all the normal other things such as fluid levels, vacuum doors, the engine temp is fine, etc. and figure that the core is clogged. My question is, how much coolant will come out if I just take off the hoses to the core in order to flush it back and forth with a garden hose? I will also be cleaning out the pressure valve in the line to make sure it is working properly. I would like to try it out before flushing the whole system in case I need to actually replace the core. Any info would help or if anyone has any pictures of when they did it that would be great too.
Old Oct 20, 2009 | 07:15 AM
RichS's Avatar
RichS
Mine was just blocked. I had very poor heat or it would be there for a second then none. I was changing my optispark, and already had the coolant drained when I blew compressed air through to core and it cleared it. I tried blowing through with me blowing in the hose and couldn't get anything through. I have to refill tonight to check it all out.
Your prolly better to just drain all the coolant then flush the core, then start fresh with new coolant. A fun messy job lol.
Old Oct 20, 2009 | 07:46 AM
pcolt94's Avatar
pcolt94
You need to disconnect both lines to the heater and run a garden hose thru it both ways several times. The debris will come out with the water. Don’t try to over pressurize it but just have a good flow.
It would be wise to also do the whole system since you are going to loose a good deal of the coolant anyway. And especially if it was clogged you want to get rid of as much of that old coolant as you can. I would also drop the lower radiator hose and flush the radiator best as possible.
Besides how long has it been since it was flushed? Over 2 years your due.
Old Oct 20, 2009 | 08:14 AM
pappy.72's Avatar
pappy.72
Thanks guys. I will be flushing all of it as the car is new to me and I don't know when it was last flushed.
Old Oct 20, 2009 | 05:51 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
When the winter comes along so do all the heater core related posts.
I fixed the control valve in the water line to the heater core to remain open permanently. This prevents heater core rot by continuously circulating the water. No problems with the A/C
Still have a new core on the shelf.
Old Oct 20, 2009 | 07:17 PM
Aardwolf's Avatar
Aardwolf
I've got my stock heater core out while doing interior work and flushed it out. After many many flushes (fill and shake) there was still junk coming out, I pretty much got tired of flushing it.
Old Oct 21, 2009 | 02:52 AM
samsonb's Avatar
samsonb
If I had the original heater core out, I would just replace it. That would be the best time to do it as it will leak eventually. Plus, the plastic tubes can crack when you remove and install the heater hoses with it being so old. I think the new ones are metal.
Old Oct 22, 2009 | 10:54 AM
CFI-EFI's Avatar
CFI-EFI
The heater, water control valve was last used in 1987.
I hate the idea of replacing parts that haven't failed. But because of the amount of labor involved and the age, an original core, absolutely should be changed if it is out for any reason.
RACE ON!!!
Old Oct 22, 2009 | 03:33 PM
pappy.72's Avatar
pappy.72
I am hoping the flush fixes the heater core because I don't feel like going through all that to take it out. It is not leaking so I hope it is just clogged.
Old Oct 23, 2009 | 03:07 PM
samsonb's Avatar
samsonb
RACE ON!!!
Yeah, I agree. If it was the radiator that was out, I'd put it back in as long as it wasn't leaking. But that heater core is a bitch. Plus with the age, you could crack the tubes in the heater core just removing and replacing a heater hose.
That would really suck you put the original back in, then you crack it when you put the heater hose back on.
Old Oct 23, 2009 | 05:53 PM
pappy.72's Avatar
pappy.72
I won't be taking it out to flush the heater core so I won't be replacing it. I will be just flushing it throug the lines and hope it clears it out.
Old Oct 23, 2009 | 09:31 PM
94vettelover2's Avatar
94vettelover2
Flush cooling system throughly & replace coolant with green!DO NOT use Dexcool!Seen too many problems at my shop with Dexcool.Also GM had a lawsuit over it.It damaged gaskets causing them to leak during warranty period.I can give you the TSB(technician service bulletin) if you like.Dexcool sucks,trust me.I cannot say enough about how bad this stuff is for gaskets,seals,radiators,heatercores etc.Never seen the same problems with green coolant!I will bet my Corvette green is better for everything in your car,just drain & fill it every year or so.If anyone tells you different they are WRONG!
To Heater core flush questions
