Hard Brake Pedal
Any ideas?
1994 coupe
The ABS check sounds like another problem.
I was told that original owner had replaced the booster and it was evidenced by a non-functioning cruise control (brake switch adjustment) and mal-functioning sports seats (from seat removal, air pump hose disconnected and lft/right harness swapped). OO was deceased at time of purchase.
Any ideas?
1994 coupe
...sound like it could be the vacuum booster hose or CHECK VALVE.
...just pull out the valve CAREFULLY and then inspect the grommet for tears, etc...the valve can be replaced by itself.....
So i tried it with my 90 c4, well i only got 1 and a bit presses before it went hard!
and the only time i hear the vacuum sound is when the engine is running and i push the pedal!
I thought this to be strange as it's going against what other are saying should be the case!
So i tried my brakes in a 98 commodore and (with engine off) i got 1 press before pedal went hard, and vacuum noise when pressing it when engine on! (same as the vette)
also i tried a brand new ute and the same thing happenen!
So its seems that a hard pedal should result after 1 press with engine off! and the vacuum(hissing noise) is normal while engine on!
After saying this my c4 pedal needs to be pushed about 1/3 of it's travel before begining to brake! and even then it requires some effort to pull the car up! my guess is it needs bleeding!
This feature was built into the brake systems for safety where if the engine died you would not loose you ability to stop the car immediately and would have a reserve of vacuum to give you 2-3 good pumps of braking. This is why there is a check valve to hold the vacuum in the booster. With every pump the pedal does get harder until you deplete the reserve vacuum at pump 4 or so depending on depth of pedal travel and other specific factors.
When the engine runs and you push the brake you can hear a whoosh or vacuum being released. However there is a difference in sound between a normal sound of a booster and one with a vacuum leak from the diaphragm.
If you are experiencing something much different perhaps there is a problem.
The only reason i have begun to investigate the vettes brakes, is because they don't feel good at all and i know they should be better, so it got me interested in comparing them with other car's brake systems!
And as you say that the 3x pedal thing, before it loses vacuum is normal, well i have found that every system i have checked with concern to engine off and the amount of times the pedal can be depressed, is 1 and a bit! I have checked the vette, a 10 year old car and a new car! all the same!
So if it is common knowledge between members on this forum that it should be 3 presses, then i'm stumped!
I'm not saying that they are all wrong, but maybe, just maybe their cars have a stuffed check valve/booster?
My pedal with engine on is definately not hard, it feels ok just doesn't pull the car up very quickly unless a descent amount of pedal effort is used!
Others may just pump it a bit and get three pumps. but if you are pumping iron at that gym and then pushing that pedal....that may explain the difference.
I'm just guessing.
If you don’t know by now than C4s have brake issues. Getting good braking and stopping power can be a problem. After replacing many things in my own car and upgrading the brake system seems like the pad material is a bigger factor than other cars. Last pad I went with was the Hawk HPS which did not work out as I expected although others like them. I ended up with (month ago) Brembo pads which really work well for me. I can really stop quick get rubber squeal and activate the ABS.
If you want to bleed the brakes fine or even replace the fluid. But air in a system will really give you a sponge feel. It never helped me because I never had air. My solution was to find the right or better pads.
pcolt97: yes i have come to learn that the brakes aren't as good as had expected(especially for a sports car)
I too think the pedal and rod adjustment seems fine! and it doesn't seem spongy, i am guessing the Previous owner used cheapish pads and/or just haven't bedded in properly!
In Australia on my other cars i use Bendix!, they seem to be a good pad, not too cheap, not too $$$$
I will try to source some to fit the vette brakes!
thanks for your help
What's "ute"?
There is a rod adjustment that needs to be made when replacing the booster. If out of adjustment you end up with what you describe.
I had to press very hard to get it to slow to a stop.
Is this a booster problem?
Herb
I don't know how to do it as I have an '84....but there are many threads on the topic.
ABS Codes....or something like that.
