Egr valve
Old Oct 22, 2009 | 11:33 AM
Ray85Vette's Avatar
Ray85Vette
Default Egr valve
I have a 85 vette , i found no vacuum line going to the egr valve solinoid.how would this affect the way the car runs?code 34 comes on and car is barly drivable
Old Oct 22, 2009 | 11:59 AM
cumbercr's Avatar
cumbercr
You should have an EGR solenoid valve located on the right rear corner of the intake manifold. Two vacuum lines connect to the solenoid. One goes to the EGR valve and the other to the bottom of the throttle body. If vacuum is disconnected from the EGR, it will throw a code. If a vacuum line is disconnected and not plugged, that will cause some performance issues.
Old Oct 22, 2009 | 02:11 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
There should be a vacuum line sticker under the hood, fan shroud?, that shows what vacuum lines go where. The line being off would cause the code, but I don't think it would make your car barely drivable.
Old Oct 23, 2009 | 06:52 AM
Ray85Vette's Avatar
Ray85Vette
Thanks guys! Fixed egr (replaced) valve,car seems to run much better.code 34 not there anymore!
To Egr valve
