My car died while driving.
Old Oct 23, 2009 | 10:56 AM
guno89's Avatar
guno89
Default My car died while driving.
1989 6 speed
Battery I would say 3-4yrs old
Alternator replaced 5-7 yrs ago
I was driving Wednesday and my volt light came on. I was at 11.3 it started dropping. It was great I was on a 7 mile bridge, I made it about 5.5 miles over and the car died. Volts where about 6.7.
I charged the battery overnight and it said full charge. I turned the car on 11.4 volts. I tested volts with car off using a multimeeter it was 11.95. I turned the car on and it dropped to 11.74 I turned on AC and the volts stayed around 11.74. I don't have much or any mechanical knowledge. Of what I understand shouldn't the volts go up when car is on since the altenator is charging the battery?
I am pretty sure that the battery is bad I am going to pull it to get it tested today. Unfourtantly since it died while I was driving and the volts i explained above, I think the altenator might be bad. How hard is this to change it looks like it is just a couple of bolts and the large pully. Is there more to replacing this than just taking the bolts of and a few electrical connections and a pully. It looks like I can do it myself.
Thanks in advance
Old Oct 23, 2009 | 11:24 AM
383vett's Avatar
383vett
If the battery is that old, it's pretty much done and might not be able to hold a charge. Time to change it. Only $50 or so. If the voltage is still low, time for a new alternator. It's pretty easy to change. Actually your simptoms sound more like an alternator problem but the battery is getting pretty close to the end of it's life.
Old Oct 23, 2009 | 12:11 PM
guno89's Avatar
guno89
The battery is 100% dead after a full charge it's 11.4 volts.
Old Oct 23, 2009 | 03:29 PM
guno89's Avatar
guno89
I drove car to auto parts store. They tested battery and alternator. Battery is good Alternator is bad. They will have the part at 8am for me tomorrow. This is my first time doing an Alt. Any sugestions or resources on the web to help me. I know i need the belt tension tool i am going to use the free rental for it.
* After my 10 mile round trip as I was turning into my parking spot at my apt complex. Car died and would not start. I'm glad I made it home.
Old Oct 23, 2009 | 03:53 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
A pretty easy job. Be sure to remove the negative battery cable 1st. Remove the belt, wires and bolts.
Old Oct 23, 2009 | 04:02 PM
j-wireman's Avatar
j-wireman
Same thing happened to me--with a new battery. Had the alternator rebuilt for $90. No problems in two years. Happened a mile from home. Glad I wasn't on a bridge.
Removing the alternator is not hard. Keeping the belt lined up with all the pulley wheels while pulling back on the tensioner was a little aggravating, but I got it. You will, too. Tools: Socket set, nut driver, tensioning tool.
You'll be on the road again in no time.
Old Oct 23, 2009 | 04:19 PM
guno89's Avatar
guno89
I never new a nut driver was called a nut driver. this is going to be my first ever car repair. Other than plugs, wires and a fuel filter and assisting with brakes. I made a decision that If i am going to keep this car for years and years like i plan too. I am going to have to be able to work on it myself. Hopefully if this goes well I can figure out why my cooling fan never goes on. I have a multimeeter now, so i can test volts. that post will be next.
Thanks for all the info
To My car died while driving.
