View Poll Results: How many miles have you gotten out of your Opti
<25,000
12.86%
25K to 50K
12.86%
50K to 75K
22.86%
75K to 100K
12.86%
>100K
38.57%
Voters: 70. You may not vote on this poll
Poll: Opti Failures.
Old Oct 24, 2009 | 12:44 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Originally Posted by Weav's Vet
Hummmmmm.... wonder if bad opti is my problem? We'll see.
If you have an extra laying around, give her a shot and swap it. Its not fun, but optis can break easily.
Old Oct 24, 2009 | 12:45 PM
jimg's'93's Avatar
jimg's'93
What appeared to be an original opti failed at about 130k when I failed to remove enough coolant on a simple t-stat swap. I'm not too sure how much longer I'd have had with it though. The rotor was loose, seals were nearly gone and I could see obvious wear on the contacts.
My current cheap aftermarket has been in now for about 4k miles.
Old Oct 24, 2009 | 07:05 PM
reoch999's Avatar
reoch999
My 92 went 120k+ original, rebuilt and converted to vented with MSD cap & rotor kit about 1500 miles ago.
Old Oct 24, 2009 | 10:07 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by MK 82
Were your replacements all OEM?
Yes, and the first one was dealer installed.
Old Oct 24, 2009 | 11:36 PM
quickcat's Avatar
quickcat
I have over 150k miles on my 92 LT1 and have not had to replace the opti... however I did put the Delteq kit on a while back. It actually made my car run smoother. I had had some ignition stumbles after washing the engine one time and figured I should do something. Replacing the opti with another did not make sense to me. It is really a poor design to put such a high maintenance item in such a difficult area to access.
I also suspect that the opti was changed once before I got the car. I can't prove it but I do know the water pump was off before.
Matt
Old Oct 25, 2009 | 01:17 AM
MK 82's Avatar
MK 82
It appears that, for the majority, it is not high mx.
Matt
Old Oct 25, 2009 | 01:25 AM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
I replaced mine when I had the water pump replaced and a bad oil leak in the front of the engine at 150K+ so it had me a bit worried as to if it would go out next.
The opti wasnt acting up, but I figured if everything else was giving out, and I was replacing so much stuff anyway, it was a "while you are in there" moment.
Laura
Old Oct 25, 2009 | 04:43 AM
jwt1603's Avatar
jwt1603
Replaxed it at 104K when tracing anignition problem that turned out to be an )2 sensor. Then put in an MSD that worked great for me. Then built a new motor with an Accel opti. It ran for almost an hour before the rotor came off and trashed it. Put a GMPP one in but put loctite on the rotor screws before installing it.
Old Oct 25, 2009 | 09:29 AM
tblt44's Avatar
tblt44
I only can assume its original with 72,000 miles on it.
The carfax did not show any repairs like this done only coolant flush and check electrical system 2 times.
Old Oct 25, 2009 | 07:07 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
My Opti in my '93 was replaced at a little over 61,000 by the previous owner. The car is running fine with 85,000 and some change on it.
Old Oct 26, 2009 | 09:22 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
My original opti went at 101-102 K cause of the waterpump
Replaced it with a Dynaspark back when they were a supporting vendor and active on the forum. Have about 3K on the Dynaspark with no issues.
Old Oct 26, 2009 | 10:05 AM
Greg Gore's Avatar
Greg Gore
Replaced the Opti in my 96 AT 110K miles when I had the engine apart for cleaning and to fix oil leaks. It didn't need it and even thought you can't really see it when the engine is back together a new one looked so much better than putting the old one back on during reassembly.
Old Oct 26, 2009 | 11:25 PM
  #33
93droptop's Avatar
93droptop
Default Been Trough two
Replaced the original in my 93 at 100K. The harmonic balancer had self destructed and the flapping rubber wore a hole in the bottom. Opti was full of dirt rust and water. Second one went at 140K, minor leak in the upper radiator hose to thermostate housing allowed coolant into the opti.
Old Oct 27, 2009 | 12:45 AM
  #34
94vettelover2's Avatar
94vettelover2
1994-95,000 miles-no records of being replaced-original spark plug wires,new spark plugs,assuming original opti-opti seal at timing cover has small leak(oil)-car still runs fine(knock on wood)-waterpump checked,no leak & appears original(keeping fingers crossed)
NOTE:I only drive car on nice(none rainy)days,& replaced thermostat & rinsed area(opti)after.Car ran rough for a little bit but cleared up just fine(lucky).Car is also washed by hand.
Old Oct 27, 2009 | 12:46 AM
  #35
mtwoolford's Avatar
mtwoolford
had 120,000 miles on car when I changed out opti on 96; previous owner changed cap and rotor four years earlier; dont know if opti was the original; do believe opti would have kept going except that vent hoses had rotted off.
Old Oct 27, 2009 | 11:17 PM
  #36
SJW's Avatar
SJW
OEM unit failed at 19,xxx miles on my '94. Replaced it with a DynaSpark unit, and it's still going strong at 56,xxx miles.
OEM unit still working just fine in my LT4 at 38,xxx miles.
Live well,
SJW
Old Oct 28, 2009 | 11:25 AM
  #37
techvette's Avatar
techvette
My roommate's LT4 had an aftermarket Opti installed by the previous owner. It lasted a year / about 4,000 miles before is **** out...Frikkin' junk! Moral of the story: don't put cheap-azz e-bay parts on your Corvette!
To Poll: Opti Failures.
Old Oct 28, 2009 | 12:50 PM
  #38
Red Rocket's Avatar
Red Rocket
Originally Posted by steve40th
First was OEM around 50k miles, due to water intrusion
Second around 25 kmiles more, it was genuine OEM. Next was with new motor around 115000 miles by odometer. Then the dilemma began, when they started breaking (Dynaspark, OEM blah blah). Install is so important. ABout 3 more, finally cut rotor off went with DELTEQ.
Sounds like my story. The poll should include cars with stroker motors or heavily modded. Went through 1-2 a year, usually blowing up at the track. No problems since Delteq.
Old Oct 28, 2009 | 01:13 PM
  #39
Capt. Mike's Avatar
Capt. Mike
'95 with 77,000 miles original Opti with no problems.
Old Oct 28, 2009 | 02:00 PM
  #40
corvette-pilot's Avatar
corvette-pilot
oh - oh
now you gone and dun it
