Hot Headers?!`
Old Oct 23, 2009 | 08:57 PM
Gregory VanLare's Avatar
Gregory VanLare
Default Hot Headers?!`
I've been struggling getting my 85 to run again. It's begun to run hotter, I've done the timing, replaced plugs, wires, rotor and cap, fuel filter and put the fuel pressure at about 42 lbs. I thought the cat blew out and plugged the mufflers so I've pulled them off (replaced the cat which looked gutted but never was). When I let it idle in the garage at night, if I turn off the lights the headers are glowing slightly. Thought it might be a bad injector but it is not just one cylinder as I'd originally thought. I replaced the injectors 2 years ago with rebuilt ones from Cruizin Performance. I'm not a diagnostitian and am wondering what else to check??!!! It's been running poorly but with no codes. When I push it, it sometimes will run like it used to but then throws a code (Missing Cal Pack)? I've not been driving since I noticed the headers "glowing"!!!!
Old Oct 24, 2009 | 03:31 AM
mnstrlt1's Avatar
mnstrlt1
Exhaust gas temps being too high means it's running lean. I wouldn't be surprised if it's the injectors again. the older design injectors (especially on these cars) aren't very good.
it's got to be timing or fuel, my guess is fuel. ... have you checked the fuel filter, have you checked the actual pressure at the rail with key to the on position?
Old Oct 24, 2009 | 10:21 AM
cumbercr's Avatar
cumbercr
When did this problem start? It sounds like it is running lean. There could be a vacuum leak somewhere or air entering the intake downstream of the MAF.
Old Oct 25, 2009 | 03:36 PM
Gregory VanLare
I replaced the fule filter, did the fuel pump a few years ago. The injectors are rebuilt 87s I think, know they are not maltecs. Fuel pressure at the rail was 38, I raised it to 43. Will drive it again tomorrow. I think the mugglers may be blocked so I'll run without them.
Old Oct 25, 2009 | 05:23 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Stupid question but sometimes it is the obvious that gets us.
When you set your timing did you do it with the EST disconnected?
Did you set it to 6* ?
Old Oct 25, 2009 | 05:43 PM
whalepirot's Avatar
whalepirot
Not sure than headers slightly glowing in the dark is what I would concentrate upon. I'd be much more interested in vacuum gauge readings and what the spark plugs 'read'; also what the fuel trim is doing.
With no unmetered air (vacuum leak downstream from the MAF), and other basic engine (timing, etc.) things in order, I'd reset the ECM by disconnecting power to it, then see if it runs better. The ECM can learn bad things which are best erased. The price is right on that one, too.
Old Oct 25, 2009 | 06:06 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
You are running lean if headers are glowing. Misfire, crossed spark plug wires (wrong ones on plugs), timing way off. Easy to due if EST wasnt disconnected when setting timing.
Old Oct 25, 2009 | 08:02 PM
Gregory VanLare
Yes, when I let it idle while timing with the EST disconnected the headers got bright red! When reconnected they were much fainter. It's set at about 9 degrees advanced. When at 6 it ran really rough.
Old Oct 25, 2009 | 08:22 PM
steve40th's Avatar
steve40th
Whats the factory timing supposed to be? AC on off? Warmed up, closed loop?
Usually its warm and at the correct idle speed which is probably 550-650 rpm.
Old Oct 26, 2009 | 04:01 AM
USAsOnlyWay
I believe factory is 6*. Is the tune stock though? What was the timing at before you did this? Was it having the same issue then.
My headers don't glow when I set timing but I usually don't take long to do it either. They shouldn't be glowing period when everything is hooked back up. And all the pipes are glowing, not just one or two?
Old Oct 26, 2009 | 05:02 PM
Square's Avatar
Square
If your car is running rough at 6 degrees, then I would check to see if you have a slipped harmonid balancer and I would also replace your O2 sensor.
An O2 sensor can get "lazy" over time. It will still function, so it will not cause a check engine light or code, but it will send inaccurate information. On my 86' the O2 sensor was sending a constant "lean" signal, so the engine ran super rich all the time.
Old Oct 26, 2009 | 05:33 PM
Pwnage1337's Avatar
Pwnage1337
85's came from the factory with 24lb injectors, i'm pretty sure every year TPI after that came with 22's. Could this be the problem?
Old Oct 30, 2009 | 07:32 AM
Gregory VanLare
I've got 22# injectors which is what everyone in the past has told me it runs. Engine is not modified. I had it tuned, allegedly, at the garage and it did run better after they timed it but that didn't impact on the glowing headers. They all glow too. I've got a new O2 so I can replace that. It is not throwing any codes but the tailpipes look like it's running rich but the scanner says it's lean, may be the solution! Thanks, I'll let you know.
To Hot Headers?!`
