speedometer install
Old Oct 27, 2009 | 10:01 AM
little98dime's Avatar
little98dime
Default speedometer install
Hey. I have a 1985 and it has a built 350 in it and I am trying to convert to analog gauges. What would be the best way to install the speedo? Also, where would be best to splice into for the volt meter?
Old Oct 27, 2009 | 02:27 PM
little98dime
I got to looking at my Haynes manual and from the looks of it, I should just attach it to the VSS and then find a suitable ground. Am I right?
Old Oct 27, 2009 | 07:14 PM
little98dime
no one has any input?
Old Oct 29, 2009 | 09:49 AM
little98dime
Hmmm. No one at all?
Old Oct 29, 2009 | 10:03 AM
engle1147's Avatar
engle1147
There is a little more to it than just that. The VSS must not only go to the speedo but through it to the ECM as well if your still running a OEM fuel injection application. Here a thread that touched on this issue which might help with what your doing:http://forums.corvetteforum.com/c4-g...-question.html Good luck with the project.
Old Oct 29, 2009 | 10:44 AM
little98dime
Ok. Well, the motor is carbed. It has no sensors going to the ECM. Basically, the ECM is not being used. I am making assumptions on the tranny being stock. Thank you for the link, it should help me a lot since he has the same situation. I don't know why it didn't show up in the searches I did.
To speedometer install
