85 High Idle Problem
Old Oct 29, 2009 | 02:22 PM
cumbercr's Avatar
cumbercr
Default 85 High Idle Problem
I've been trying to get to the bottom of a problem with idling too high. I've replaced the IAC valve and verified the throttle cable is not binding. I adjusted the TPS to .54 volts. Before I spend money on a new TPS, is there anything else I can check? By the way, I can sometimes get the idle to drop by hitting the gas pedal with the brake on and in gear.
Old Oct 29, 2009 | 03:50 PM
Square's Avatar
Square
Have you cleaned the throttle body?
Have you done a "Base Idle Reset" procedure?
What is the current idle RPM (both in gear and in neutral)?
Old Oct 29, 2009 | 04:05 PM
ant-knee470's Avatar
ant-knee470
Just a thought,
Is it possible the throttle return spring has weakened?
Ant...
Old Oct 29, 2009 | 04:49 PM
Sweet 90's Avatar
Sweet 90
This should be a sticky, some good info here.
Jim
http://temp.corvetteforum.net/c4/vader86/tpsiac.html
Old Oct 29, 2009 | 07:35 PM
fevest's Avatar
fevest
Your throttle cable may be worn. That is what mine acted like. The cable was frayed inside and would not always return fully. Easy enough to fix, you can get cables several places.
Old Oct 29, 2009 | 07:41 PM
cumbercr's Avatar
cumbercr
I did disassemble and clean the throttle body when I replaced the IAC. I've set the idle several times per the FSM.
When it does idle properly, its around 750 rpm. The guy who burned the chip thought that would be a good idle for my combo.
Old Oct 29, 2009 | 07:46 PM
cumbercr's Avatar
cumbercr
Originally Posted by ant-knee470
Just a thought,
Ant...
Today, it was idling at 1200 rpm when I pulled into the garage. I checked all the cables while it was running. The throttle cable had play in it and the throttle was fully closed.
Old Oct 29, 2009 | 08:18 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Do you having any scanning ability to see the IAC counts and spark advance ?
Have you searched for vacuum leaks ?
To 85 High Idle Problem
