How can you tell if your injectors are really bad. Through the process of elimination, I am guessing this is going to be my problem. I have used an OHMS meter to test resistance across each one and got a reading on all 8 of them of 9 on the 1X scale on the meter. You can hear what sounds like them firing and feel them pulsing when you put put your finger on them. My fuel pressure is good all of my plugs, wires, cap, rotor and fuel filter have just been replaced and it is still running rough at idle and when the throttle is advanced.
if they all read 9 i would say they are bad as they should read 16. However, to have all at 9 would tell me your ohm meter or test procedure was wrong. I would think the odds of that are very high that all the coils are shorting the exact same.. Do it again, but test the ohm meter first.. If that is the true reading then call us we have new or rebuilt injectors at great prices,
Did you do any pressure tests ?
What OHM numbers, did you get ?
You vette came with problematic injectors, there is a very good chance that they may be failing.
Jon at FIC can hook you up with reasonably priced injectors, if you find the need.
He has a sticky at the top of the tech section, have a look at it.
How about an answer? You ask for help. Get it and leave it hanging.
If you have a big miss then check the plugs to see if it looks like gas is getting to the cylinders. I agree with Jon in that it is strange for all your ohm readings to be the same.
Or, if you have a scanner you can look to the fuel numbers the scanner gives you at idle in closed loop. If you have a FSM, in the 6E section there is a page that is a "snap shot" of what a normal motor looks like on a scanner. Just compare the info and post up the differences for us to look at so we can help diagnose the issue.
I would also say that the early mulitech injectors, before 92 or 93, were not designed to work with the methanol in the gas now. The result is that the methanol attacks the insulating epoxy in the coils and shorts them out causing the injector not to fire.
