58mm Throttlebody
Old Oct 31, 2009 | 01:14 PM
'08coupe's Avatar
'08coupe
Navigator
Default 58mm Throttlebody
Hey Folks,
Just wondering if anyone has experienced a flat spot when replacing the factory throttle body with a 58mm unit. It seems as though I now have this sort of flat spot around 1800-2000rpm at mild throttle. Below that and above that it is a real champion. Any help would be nice.
Old Oct 31, 2009 | 01:26 PM
jimg's'93's Avatar
jimg's'93
I have not replaced my stock tb, but can I ask why you replaced yours with a 58mm? Did you do other mods as well?
Reason I ask is that a 58mm tb is pulling in a helluva lot more air and I'd think it would cause problems on an un-modded engine. I'd also think you'ld want a pcm tune as well.
Old Oct 31, 2009 | 01:30 PM
CFI-EFI's Avatar
CFI-EFI
Too big for for anything even close to stock. Even 52 mm is often overkill.
RACE ON!!!
Old Oct 31, 2009 | 06:39 PM
aboatguy's Avatar
aboatguy
No flatspots with my 58mm TB, but I have one or two engine mods
Old Oct 31, 2009 | 07:09 PM
STL94LT1's Avatar
STL94LT1
It would be nice to know the year of your car and if any engines mods have been done.
Check to make sure the TPS is working properly.
Old Oct 31, 2009 | 07:27 PM
combustables's Avatar
combustables
I put a 58mm TB on my 383 and immediately experienced an idle lope. I had a pcm tune done to match the new motor and the lope dissappeared as soon as I put the original 52mm tb back on.
It was a waste of money in my opinion and un needed.
CFI-EFI it's good to see you posting again.
Old Oct 31, 2009 | 07:48 PM
rodj's Avatar
rodj
As I have previously posted , I did back to back testing 48mm v 58mm (350 ,intake mods , SLP's, ZZ4 cam,A4 , 3.07's)
30 runs on same day;
No difference in ET /speed , no difference in 60ft , no WOT lag / flat spot ,no drivability problems.
Obviously not a worthwhile bang for buck investment but not the horror story some claim ( loss of bottom end , etc)
Old Oct 31, 2009 | 09:17 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
My 58mm seems to working and running fine. I'd like to see how it would do on a smaller one but I'm too lazy to go changing things right now. I'm still running a good PCMforLess tune right now, but plan on taking for a dyno tune in the spring. We will see then what shakes out.
Old Oct 31, 2009 | 11:29 PM
383vett's Avatar
383vett
My 58mm throttle body works well on my 406. No flat spots, but I usually go from idle to wot.
Old Nov 1, 2009 | 08:50 PM
Red Rocket's Avatar
Red Rocket
Upgraded to the 58TB with the new AFR 195CC LT1 Eliminator Competition heads and ported intake on my 396. Only way to go with the right combo and tuning.
Old Nov 1, 2009 | 11:03 PM
383vett's Avatar
383vett
I think with mods (heads, cam) or a larger displacement, the 58mm throttle body will increase performance.
Old Nov 2, 2009 | 09:17 AM
JackDidley's Avatar
JackDidley
One or two ??
Old Nov 2, 2009 | 11:25 AM
'08coupe's Avatar
'08coupe
Navigator
Default answer
I have no mods yet. I was informed that this TB would be the way to go as it is not a "re-made" piece, that it's a fully machined unit and as I start the mods, it would be a great addition. When I inquired as to any difficulty on a stock motor - I was informed this shouldn't be a problem for now. It is not a huge problem if it is going to go away as mods get done, but if not, this would really suck.
The mods planned for next season are ported heads, cam, LT headers/hi flow cat/and exhaust. I will also be doing some sort of air intake mod and computer tuning.
Old Nov 2, 2009 | 12:40 PM
383vett's Avatar
383vett
On a stock motor, I would think the 58mm would require a tune to work well. The tps senses a throttle position change which is different from a stock throttle body compared with a larger one. A large one will let in more air for the same throttle position change and possibly give you the flat spot you are experiencing.
Old Nov 2, 2009 | 01:48 PM
LT4BUD's Avatar
LT4BUD
First question is what motor are we talking about????
In any event to just bolt a 58mm tb on to a stock manifold does create a problem.....the intake ports on the stock manifold are less than 58mm which creates two issues...
First issue is you will not get the flow of the 58mm openings since now the intake manifold with smaller openings is restricting your flow..
Second and perhaps worse is the turbulance created when the air flow hits the sharp openings on the intake manifold..
This is such an old rehashed topic.....from an old old thread probably 10 years ago someone on the forum did a baseline dyno, dyno with the 58mm tb on stock manifold, then dyno after the intake was opened up
I do not remember the actual numbers, but just mounting the 58tb on a stock manifold actually resulted in a very small loss of hp.....after opening up the intake manifold there was a small, but nice increase in power..
BTW I have no dead spots with my 58mm tb..
Old Nov 2, 2009 | 04:38 PM
rodj's Avatar
rodj
Originally Posted by LT4BUD
I do not remember the actual numbers, but just mounting the 58tb on a stock manifold actually resulted in a very small loss of hp.....after opening up the intake manifold there was a small, but nice increase in power..:
At this point your $$$ would be better spent on other things that will give to instant/ not future results
Old Nov 2, 2009 | 10:09 PM
aboatguy's Avatar
aboatguy
58 MM bolted right up to my LT1 intake with no issues.
Old Nov 2, 2009 | 10:18 PM
383vett's Avatar
383vett
Man, that thing looks like it can use a 90mm throttle body (maybe 2).
To 58mm Throttlebody
