Need quick answer - thanks!
Old Feb 26, 2002 | 11:26 AM
95DropTop's Avatar
95DropTop
Default Need quick answer - thanks!
Will C5 rotors fit on a 95 C4??? Thanks in advance for all the answers! :cheers:
Old Feb 26, 2002 | 12:06 PM
DON M's Avatar
DON M
Default Re: Need quick answer - thanks! (95DropTop)
There is a company that sells brackets that will adapt the calipers. You need to use the C-5 rotors and they are supposed to work. The Z06 calipers are red but are the same as the regular grey ones. Zips sells the full kit for about $1000. It is supposed to be a killer Mod. I am planning on doing this myself this summer. If you buy the brackets only they are about $400. I thought they were from Electromotive but I can't find the link. Seems like a rip off price.
Good luck, DON M
[Modified by DON M, 11:07 AM 2/26/2002]
Old Feb 26, 2002 | 12:10 PM
95DropTop's Avatar
95DropTop
Default Re: Need quick answer - thanks! (DON M)
But can I use the rotors from a c5 and everything else from my c4?
Old Feb 26, 2002 | 12:22 PM
VetteNoob's Avatar
VetteNoob
Here, check this out. I found it on a different thread. I've been saving links for future projects :smash: Let us know how your project goes!
http://www.superchevyperformance.com/misc/c5brakes.html
[Modified by VetteNoob, 10:22 AM 2/26/2002]
Old Feb 26, 2002 | 03:15 PM
DON M's Avatar
DON M
You have probably seen the other thread by now, but no they are much wider and will not fit into the caliper.
Old Feb 26, 2002 | 03:16 PM
95DropTop's Avatar
95DropTop
Thanks - yes I did see it :cheers:
Old Feb 26, 2002 | 03:29 PM
92TripleBlack's Avatar
92TripleBlack
No you can't. C5 rotors are 1.25" thick. C4 are 1.1" thick. The C4 calipers will not fit around the c5 rotors. You can mount the calipers but you need the electro-dynamics brackets to hold them or the bracket kit made by vette brakes that is in the Zip GP. The upgrade to C5 will cost you about $700 in total for all the parts. Definitely worth it for people without the big brakes. For you, you'd need to judge for yourself. Lastly, the rear C5 don't fit at all. The E.D. people were putting together a kit to allow the C5 to work but the C4 rear is actually a better brake.
Old Feb 26, 2002 | 03:30 PM
DON M's Avatar
DON M
http://www.electro-dynamics.com/
I just saw Jeff Kopps Info on the conversion and found the link for the special brackets. They aren't quite $400 but stiil a chunk of change.
To Need quick answer - thanks!
