H Retractable headlight problem
Old Nov 1, 2009 | 09:40 PM
J H's Avatar
J H
Default H Retractable headlight problem
The left headlight on my 85 begins to open and then stops about midway. I can push it open the remaining portion of the way with the motor helping a bit. What problem do you think I have? Bad motor or bad gears? The white gear was replaced about 6 years ago (maybe less). The black gear was not replaced at that time.
Old Nov 3, 2009 | 10:16 AM
josephf31's Avatar
josephf31
Default My guess
would be the gears.
Old Nov 3, 2009 | 10:21 AM
jhammons01's Avatar
jhammons01
^^Not Necessarily, if there is no grinding occuring (which you seem to know enough about the gears) I'd say you have motor that is getting tired. It happens ya know.
Look in the old part of your town, you may find a guy that rewinds electrical motors.
You may also inspect the wiring, it may be corroding 'causing a low voltage situation
Old Nov 3, 2009 | 10:25 AM
J H's Avatar
J H
Thanks. I have the gears ordered and will install as soon as they come in.
Old Nov 3, 2009 | 07:21 PM
Red C4 n VA's Avatar
Red C4 n VA
5th Gear
I had a similar problem with my headlight (89 model) and was told it might be the bushings. I found this great article on Corvette Fever --
Make Your C4 See Well
Five Bucks Can Cure Your C4’s Lazy Eye
http://www.corvettefever.com/howto/33098/index.html
Also, I see in the article they do call out gears for 84-87.
Old Nov 3, 2009 | 08:32 PM
J H's Avatar
J H
Thanks, but the 85 does not have those "bushings", it has gears that have to be replaced.
Old Nov 4, 2009 | 02:29 PM
steve2001sh's Avatar
steve2001sh
You may want to try watching it closely with the hood up while it flips too. I noticed one of the arms hitting the motor and getting stuck. It turns out one of the mounting screws had fallen out and was allowing flexing of the assembly.
I also had to replace the bushings (mine has them) the first time around. My old trans am needed new gears... What is wrong with GM and headlights?
Old Nov 4, 2009 | 02:40 PM
jhammons01's Avatar
jhammons01
J H, if you do not hear any grinding or clicking....why would you go after the gears??
To the "others" the "bushing" replacement is for the later years. The early years grind down the gears.....be careful when you advise someone to replace bushings when they have an earlier C4.......What year did they switch?? Search button is your friend.
J H, look for binding as well. The Bucket can freeze up to one side and it binds a bit. Not sure why...but my left one did that...I just spray lubed it on the none motor side of the pivot point and it stopped binding.
Old Nov 4, 2009 | 04:10 PM
J H's Avatar
J H
I just finished replacing the gears. When I opened the motor it was obvious that the gears were not the problem. But since I was already in there, I replaced then anyway. I put everything back together and still the same problem. It really sounds like the motor is bad or not getting proper current flow. I did have a broken wire which I fixed, but still little rotation. The light will sometimes go about 1/2 way open and stop. WHen I turn the lights off, it closes as it is supposed to do. I now think the motor might be bad. I'll keep researching this until I get to the real solution.
Old Nov 4, 2009 | 06:06 PM
Inlove's Avatar
Inlove
This may be off base but have you moved anything in the "headlight well" lately? When I inadvertently left the radiator overflow hose in the way of the headlight I had the same issue you are describing, although the other side. Like I said this could be off base but it's a thought???
Old Nov 4, 2009 | 06:30 PM
J H's Avatar
J H
Thanks, but there are no obstructions, etc. It seems like now there is not enough torque to raise the lamps all the way up. I do hear the motor "straining", but no movement after a certain point.
Old Nov 5, 2009 | 12:17 PM
jhammons01's Avatar
jhammons01
Did you lube the pivot points? Try some dry graphite in the pivot points and see what you get.
Old Nov 5, 2009 | 12:52 PM
J H's Avatar
J H
Yes, I did lube the pivot points. I worked with it a long time this morning and found that the motor is just worn out. The brushes are worn to the point where they are not making good contact. If I touch the brushes and pish them in a bit, the motor runs good and strong. For not I have both lights in the up position. I am looking for the best deal on a replacement motor. The best I have seen so far has been the rebuilt motors that Ecklers sells for $159.00 after the core has been turned in.
Old Nov 5, 2009 | 02:43 PM
jhammons01's Avatar
jhammons01
Try someone that rewinds Motors....here is one near you.
Southern Electric Motor Co Inc
602 N Mangum St, Durham, NC
(919) 688-7879‎
Central Electric Motor Co
Durham Fwy, Durham, NC
(919) 644-1180‎
Pull that motor out and take it over there. I promise you, if they know their craft they'll fix you up in no time.
Here is one:
Jims Electric Motor Repair
3601 Carpenter Pond Rd
Durham, NC 27703
Jims Electric Motor Repair Business Information
Jims Electric Motor Repair is a private company categorized under Armatures-Repair and Rewinding and located in Durham, NC. Current estimates show this company has an annual revenue of $54,000 and employs a staff of approximately 1.
Old Nov 5, 2009 | 03:26 PM
J H's Avatar
J H
Thanks a bunch. I'll give these referrals a call.
To H Retractable headlight problem
