Error Code 33 Info
Old Nov 2, 2009 | 09:30 AM
btr85vette's Avatar
btr85vette
Default Error Code 33 Info
I recently had a problem where my 85 Vette suddenly would barely run. I checked the error code, and it threw a code 33, MAF sensor voltage high. I bought a FSM from Ebay, and went through the diagram, and found something interesting.
After going through the diagram, and tearing part of the car apart to find the Burn Off module, I happened to notice on the wiring diagram in the FSM that there was a circuit going to the gauges. So I went to the fuse block and found a 10 amp fuse for the instrument panel, and it was blown. I replaced it and the car ran fine again. I had one of the instrument panel bulbs blow, so maybe they're related.
The whole point of this post? While the FSM has great info, it NEVER said to check the fuse! I spent a week and a half with my car down, and all I had to do was replace a fuse.
Long story short, on an error code 33, check the Instrument panel fuse first.
(and yes, I know, I will be monitoring the circuit to see why the fuse blew.)
Old Jul 14, 2012 | 01:37 AM
_Vette_'s Avatar
_Vette_
Did you end up finding out anything about this? I had the same problem with my 85. I replaced the fuse but it blew right away. I replaced it again and its holding up, but it needs to be warmed up to 170f before it will drive smoothly. If i try driving before that it has to be wide open or it dies.
Old Jul 14, 2012 | 11:53 PM
Curveit's Avatar
Curveit
I had a code 33 once that turned out to be a bad wire to the Coolant Temperature Sensor. I had replaced the MAF with no change.
Old Jul 15, 2012 | 01:09 AM
_Vette_'s Avatar
_Vette_
So i should check all my connections, not jump and get a new MAF?
Old Jul 15, 2012 | 05:01 AM
Cliff Harris's Avatar
Cliff Harris
The '85 has a MAF burnoff module (and I suppose it also supplies power to the MAF). Check your FSM to see how it's connected. I suspect it gets its power from the instrument panel fuse.
'85 was the only year to have this module, so I don't have any info on it.
Old Jul 15, 2012 | 05:40 AM
_Vette_'s Avatar
_Vette_
Thanks, ill spend all day with it and see what i can do.
Maybe its time for that ls1 swap. Haha.
To Error Code 33 Info
