Thread Repair
Old Feb 26, 2002 | 12:57 PM
TJ96CE's Avatar
TJ96CE
Default Thread Repair
Anyone use a heli-coil for thread repair? How did it work? Can a 'same size tap' be used for minor damage?
Tom
Old Feb 26, 2002 | 01:23 PM
buppies's Avatar
buppies
Default Re: Thread Repair (TJ96CE)
You buy heil-coil by the size you want to replace. It comes with tap and tells you what size drill bit to you use.Just be careful :D
Old Feb 26, 2002 | 02:13 PM
VMAX451's Avatar
VMAX451
I've used heli-coils and they work very well. If you have minor thread damage from cross threading or overtightening where you "mashed" the threads, then you could try the same size tap first. If you actually ripped out the threads, then it's probably heli-coil time though, or, in very simple cases, you could just drill and tap it out one size larger and use a bigger bolt.
Old Feb 26, 2002 | 03:13 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Default Re: Thread Repair (Vince Ivanc)
I take it that the messed up thread is the sparkplug threads inside the head. You can buy a thread chaser and use it while the head is still on the car.
The biggest obstacle (besides getting the darn thing lined up) and (turning it when you finally do get it lined up) is keeping metal outside the combustion chamber.
Don't forget to lower the piston in the cylinder if you do this ~ and use plenty of grease on the thread chaser in hopes that it will catch and hold the metal filings.
:seeya Purp
Old Feb 26, 2002 | 04:53 PM
TJ96CE's Avatar
TJ96CE
Default Re: Thread Repair (PurpleC4)
Since I have never done this(and luck seams to be against me) perhaps I should have someone ELSE DO this. What would be a reasonable price(seams like 1 hour labor)????
Tom
Old Feb 26, 2002 | 06:11 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
A good mechanic should be able to do this job in less than 30 minutes ~~~ Taking the following into account:
1. The cylinder that he has to chase the threads on has reasonable access
2. The threads aren't totally whacked :sad:
Plan on paying between $50 to $75 for the service.
:seeya Purp
Old Feb 27, 2002 | 01:43 PM
kingvet's Avatar
kingvet
They work great. I had a striped removable roof bolt on a supra i owned and used a heli-coil on it and it worked great. Just be careful not to over tap. :)
Old Feb 27, 2002 | 01:45 PM
TJ96CE's Avatar
TJ96CE
Default Re: Thread Repair (kingvet)
How do I make sure cylinder # 1 is in a good position?????
To Thread Repair
