Reset Dash Indicator Codes
Old Nov 3, 2009 | 08:48 AM
ksch994462's Avatar
ksch994462
Default Reset Dash Indicator Codes
My "Change Oil", "Seat Belt," and Airbag indicator lights stay on. I now know to clean the grounds. After I do that, anyone know how to reset the codes to shut the lights off?
Old Nov 4, 2009 | 11:50 AM
josephf31's Avatar
josephf31
Default I
think the Change Oil reset light procedure is in the owner's manual.
Need to know what year/model you have?
Old Nov 4, 2009 | 01:01 PM
pipe's Avatar
pipe
Sometimes just cleaning the grounds (under the sensors) isn't enough. It could be a bad sensor. And no matter how many times you try to clear it out the light will keep coming on. First find out what codes it flashes then you can go from there. Pipe
Old Nov 4, 2009 | 01:58 PM
ksch994462's Avatar
ksch994462
Mine is a 1990. I've tried the procedure for the Oil Change Light in the owner's manual several tmes with no result. I'm hoping that the lights just go out when I clean the grounds? Waddayatink???
Old Nov 5, 2009 | 11:00 AM
josephf31's Avatar
josephf31
Default There
are known issue with the 1990 airbag lights, if you do a forum search you should find detailed instructions on how to fix it.
To Reset Dash Indicator Codes
