When you purchase that new oil fill cap, you might as well add a new dipstick also. I just had to ge both for my 91. Oil fill cap seal and the neck of the dipstick had a piece break off and started spitting oil out under continueing high revs.
Thanks for the info. My dipstick starting spewing onto my header at the tack in the spring. I heard it was quite a fire display but no one got pictures. I replaced it then.
No gasket maker as this can detrioate & pieces can fall in filler hole.
The OEM cap on the early L98s (i.e. 84-85) have a gasket/seal on the base of the cap after +/-20 years of heat and chemicals, these get hard and brittle and can deteriorate. If you know what kind of material to look for and you know what you're doing, it's an easy fix. I see that Kubs is referring to a '90 which I'm less familiar with, but I'd expect to find an o-ring seal on the newer caps.
Yes the new ones have an o-ring. If I put RTV around it it doesnt leak, but the cap is kinda beat up anyway.
