Jerky Jriving
Old Nov 5, 2009 | 07:03 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Default Jerky Jriving
I've installed a ZZ4 in my 89 coupe. The car used to drive smoothly through the neighborhood at low speeds. After installation of the motor, the car is very jerky at low speeds and I have to keep my foot on the throttle or dis-engage my clutch to coast down the street.
I've installed all new U-joints while in there, which should help tighten up the drive train.
My questions are:
1. Can this problem be fixed in the tune?
2. I know I need a new clutch, could that be the problem?
Old Nov 5, 2009 | 07:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Custom tune would most likely solve the problem, as long as there are no underlying problems, such as a vacuum leak.
Old Nov 5, 2009 | 07:20 PM
383vett's Avatar
383vett
As agent 86 mentioned, a tune will probably take care of your problem. You are running a stock tune with a motor that has more cam and less vacuum so spark/fuel requirements are different.
Old Nov 5, 2009 | 07:28 PM
WW7's Avatar
WW7
The ZZ4 is a very different motor from the stock L98. More then 100 hp different.Hook up a scanner to it , the ECM is probable going crazy trying to compensate...WW
Old Nov 5, 2009 | 08:00 PM
dclafleur's Avatar
dclafleur
Check your timing, I had a similar problem and it was because I hadn't tightened down the distributor bolt all the way and my base timing was off.
Old Nov 5, 2009 | 08:11 PM
89Corvette6spdFX3
Thanks guys for the comments.
I've already had the tune. I was asking because I will take it back to him to fix that in the tune if that's what it could be.
Dave, I need to get a timing tape to wrap around the balancer. I used the old balancer and the new timing cover doesn't have the timing marks, just a plastic bump. I'll check it tho.
Old Nov 5, 2009 | 08:20 PM
mseven's Avatar
mseven
If you can you run a datalog that would also help you and your tuner understand what changes are needed.
Old Nov 5, 2009 | 08:31 PM
dclafleur's Avatar
dclafleur
If you've got a distributor wrench you might just mark the position and try moving it a little to see if it smooths out a bit. Have you also checked vacuum? If you've got a vacuum leak it'd idle worse. Sorry it's not running better, I'm hoping the weather is nice this weekend so I can take mine out of the garage.
Old Nov 6, 2009 | 09:27 AM
89Corvette6spdFX3
It's idling just fine. I do need him to readjust the tune for when I turn the AC on. If I can just find time to get the car down to him, that's a big problem for me too!
I do know someone with datalog equipment. I'll give him a call and see if we can pull some info. What should I be looking for specifically?
Old Nov 6, 2009 | 11:50 AM
mseven's Avatar
mseven
Originally Posted by 89Corvette6spdFX3
It's idling just fine. I do need him to readjust the tune for when I turn the AC on. If I can just find time to get the car down to him, that's a big problem for me too! I do know someone with datalog equipment. I'll give him a call and see if we can pull some info. What should I be looking for specifically?
In general look at the BLM, Spark Knock/timing, and IAC counts is a good start. On a modded motor you will want to see IAC be around 40 ct.s and idle RPM should be around 800-850, and in gear around 750ish.
The AC is an easy fix, add more counts to the IAC /AC ON, (stock setting is 5 counts in the tune). You can also add some RPM (when AC on, both in the tuning properties) which will fix the AC idle/in gear situation.
To Jerky Jriving
