What to look for C4
Been looking at some C4's at various car dealers, I'm new to Corvettes and was wondering if y'all could tell me some things to look for that would be red flags or at least questionable items. I have walked away from three that were just rags or seriously overpriced for the condition of the car. So far I have found wet floorboards, cracks around the hood where it latches and cracks around the headlights. Of course there seems to be a lot of crap paint jobs out there too....good from 50 feet.
thanks in advance
Good luck.
All bonding seams on the body are underneath mouldings, so if you see cracking or telegraphing through the paint, it was repaired.
Once you find a particular year, then we can help you find the quirks for that car. There are some great values out there in ZR-1's Grand Sports and others!
milage beauty.im sure this will bother some folks so sorry in advance.
thanks in advance
I bought a 62k mile Garage queen from the original owner...."SHE" did keep it nice but she didn't drive it for 10 years.
When I bought it an pressed it into daily service, the paint fell off....the Dash cracked....the o-rings and gaskets all developed leaks....the whole car needed ONE of everything as the OE equipment was 25 years old and very very tired.
So yeah, I passed on a ton of well kept high mileage cars....that may have been a mistake in hindsight. Maybe $4500 on a 120K "well maintained labor of love" from an actual car enthusiast would have been better than $4500 62k mile garage queen that only got serviced at dealerships "when something broke"
Right now, I'm repairing the Power Steering.....reason?? Old houses, dried up leaky o-rings....the pump itself works fine....it just drops about 4 oz of fluid per night....and the under side of the car now has it's own home made "Undercarriage corrosion resistant protection plan"
Wanna see the oily underside?? I didn't think you would....
But seriously, I've rebuilt the entire drive train minus the "Motor" itself......that is the last "component" I need to rebuild at this point.
Understand, I didn't need to rebuild things.....they were just leaking fluids....so while I had the tranny out to change seals......I had them rebuilt just in case.
This is a good plan to start with. It helped me just to keep a list of things to look at instead of getting into the "I am buying a Corvette" dream mode when I looked at a few.
Suggest you define what you really want (original/modified, basic/accessories, painted/clear top, color, wheels, sound system). Options add complexity and may or may not be worthwhile for you. Anything that varies from your "perfect" car increases expense and decreases satisfaction. And don't rush!
Will be interested to learn what you end up with...
Some require more or less maintenance depending on the care and use.
coupeguy is right with how it boils down.
I'd sugest too, call private owners and go look at their cars, they're more honest than car dealers are.
Check the car out, you'll know if something doesn't look right. Make sure everything works, headlights go up and down, windows. etc. If it's an 84 to 89 make sure the dash works. Have the owner take you for a test drive. You can concentrate better in the passenger seat without you driving it. Then wherever you end up, now you drive it back to his or her house feeling the brakes, steering and what not.
Buying a Corvette is like buying anyother used car.
Buying a Corvette is like buying any other car so check everything you would normally check and add a few other items.
First, you need to decide what you want so you can narrow down your search.
Do you prefer automatics or manuals? My wife and I both prefer manual transmissions so we went with a 6 speed. Nothing wrong with the automatics if that's what you prefer.
Is this going to be used for road trips and vacations? C4 convertibles are very limited on luggage space. That's the only reason my C4 is a coupe.
My 71 was rarely road tripped so luggage space wasn't a big deal then. My C5 vert has a trunk. If you plan to seriously race the car keep in mind the rules are more stringent for convertibles than coupes.
Which body style do you prefer? I liked the look of the later model C4s and the HP increase from 91 to 92 was a bonus so we looked for 92 and up.
Keep in mind that for their age these cars are fairly advanced with gadgets and gizmos for their age. The VATS system, ARS and ABS can all be tricky (and expensive) to repair. Not to mention the Opti spark on the LT1/LT4 cars.
Keep the Corvette tax in mind and check the operation of ARS and ABS, check the the condition of weatherstripping, interior parts like seats and door panels. Seat covers and foam can be very pricey.
Look carefully under the hood for hack jobs on wiring and hoses or other lines that don't look right.
thanks again,
