need springs ??
Old Nov 6, 2009 | 01:12 PM
LT4sawyer's Avatar
LT4sawyer
6th Gear
Default need springs ??
I need new valve springs to run w/ comp 503 cam :533/int.540/exht.with 1.6rr I have unmodified LT-4 heads.I would like to have nice springs that want break the bank or require any modification to heads.asking because I trust the advise I read on this forum and I would like to order with confidence that I have the right stuff coming.I would also like to know if I could use retainers, locks,ect... from new LT-4 springs on any of these springs you may suggest.just wondering since I already have these springs laying around NIB and my budget is tight.thanks for your help.
Old Nov 6, 2009 | 06:31 PM
rodj's Avatar
rodj
Maybe
http://forums.corvetteforum.com/c4-p...ew-in-box.html
Old Nov 6, 2009 | 06:56 PM
pr0zac's Avatar
pr0zac
patriot golds
Old Nov 6, 2009 | 08:18 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by pr0zac
patriot golds
https://www.patriot-performance.com/...&cat=52&page=2
Old Nov 7, 2009 | 09:07 AM
mtwoolford's Avatar
mtwoolford
LT4 springs are rated for .525 inch valve lift; same lift as an LT4 Hot Cam; I wouldn't recommend going to .533 inch with LT4 springs.
Old Nov 8, 2009 | 12:31 AM
LT4sawyer's Avatar
LT4sawyer
6th Gear
no not planning to use the springs.I was asking if I could use the locks, retainers,ect..with any of the other springs.mainly because I just wasnt sure and buget is always a factor.I know those springs are barely adequate for the hot cam. lol
Old Nov 8, 2009 | 01:24 AM
gaeecho9r's Avatar
gaeecho9r
comp cams will tell you what springs you need call them.. and 1.6 are needed to gain your power,but the stock flow of the heads will hold you back I hope you have headers.. If not wait until you get all your goodies together then install..so yes you can leave the heads on install cam lifter new pushrods i hope thats what you are doing old lifters and new cam not good idea..and rockers but that cam needs to flow..i think they are called bees or beehive the new stuff check out gmhitech lt1 build up or head comparison got it all there.. good luck
Old Nov 8, 2009 | 09:06 AM
STL94LT1's Avatar
STL94LT1
As long as the old lifters are in good shape there is nothing wrong with reusing them with the new camshaft.
Old Nov 8, 2009 | 09:30 AM
Mojave's Avatar
Mojave
LT4's got 1.6 RR's from the factory: http://www.grandsportregistry.com/lt1vslt4.htm
Old Nov 16, 2009 | 01:57 PM
LT4sawyer's Avatar
LT4sawyer
6th Gear
hey guys sorry to just abandon the thread tied up with family issues ,anyway I ended up going with vs-2700 valve springs from bullet racing.they were recommended by Loyd Elliott as I went with one of his cams also.these springs can be used with stock retainers,locks,ect...and are good to over .600'' lift
Old Nov 16, 2009 | 02:16 PM
ddahlgren's Avatar
ddahlgren
Do you have a part # and web addy for springs and cam. If not ok to post the vendor and part #'s please PM me..
Thanks.. Dave
To need springs ??
