89 starting problems
Old Nov 6, 2009 | 02:10 PM
blk89convt's Avatar
blk89convt
Default 89 starting problems
89 convertible starts when cold idles fine but will start to miss when you speed up and when you cut off will not restart untill cool. I have changed ignition module and coil and plugs and wires what could be the problem thanks
Old Nov 6, 2009 | 03:54 PM
engle1147's Avatar
engle1147
Check the car for stored trouble codes first and go from there. If no codes I'd look to the fuel system first. Fuel injectors - the stock (non ethenol compliant) Multechs that cam in the '89 have had high failure rates as of the last couple years. Do a resistance check across the injector coils both cold and hot and see what's up....they should be ~17 ohms across each coil.
Here is a link to the test proceedure (5th video down):http://forums.corvetteforum.com/c4-t...questions.html
If you feel your injectors are the problem get with Jon at FIC Injectors and he'll get you set up for some replacements ones @ a great price.
Old Nov 7, 2009 | 10:16 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I would check the ignition coil in the distributor. It sounds like it is old and possibly shorting out. Check the connections at the back of the block where the grounds are located.
Old Nov 7, 2009 | 09:31 PM
7SPD Z52's Avatar
7SPD Z52
Sounds like injectors. Check the ohmage... Easy check if they are stock injectors very high failure rate
Old Nov 8, 2009 | 08:13 AM
Jimbo 89's Avatar
Jimbo 89
I had same problem with my 89. Would run fine on cold start, (this is open loop mode), then when temp. got to about 140 degrees, (going into closed loop), it would start missing. FUEL INJECTORS.
As stated earlier, talk to Jon at fuelinjectorconnection.com
Old Nov 10, 2009 | 01:15 PM
blk89convt's Avatar
blk89convt
would the injectors keep it from starting back up after it has got hot thanks
Old Nov 10, 2009 | 01:40 PM
7SPD Z52's Avatar
7SPD Z52
Absolutley! This is the exact problem we just had with my 89 coupe. We thought it was ignition too. Than we learned of teh injectors. With a Digital multimeter set to ohms you can easily identify the culprit(s) In my case it was 1 really bad one (Only 8 ohms) and two not so good ones. Take my advise though, buy a quality injector. We got some cheapo's from Pep Boys and it doesnt strat as well as it used too. We'll be changing them again Im sure.
Old Nov 10, 2009 | 03:45 PM
blk89convt's Avatar
blk89convt
What kind of price does jon have on a set thanks
Old Dec 14, 2009 | 11:36 AM
blk89convt's Avatar
blk89convt
Got injectors from jon she now runs great problem solved
To 89 starting problems
