Need scanner info
Old Nov 8, 2009 | 12:13 PM
Bulldog Steve's Avatar
Bulldog Steve
Default Need scanner info
Have a 1990 and want to buy a scanner or a program to check for codes and see what the systems are doing can you guys point me in the right direction.
Right now i have a service abs light on and have the fsm but it wont pull and codes with the paper clip.
Steve
Old Nov 8, 2009 | 12:36 PM
cumbercr's Avatar
cumbercr
I just bought an Auto Xray 3000 on eBay for $89. It is a discontinued model but seems to work fine on my 85. It is also upgradeable. They have more listed. The only problem I found is that it uses a serial connector rather than USB to connect to my laptop. I need to get a gender changer for the connector.
Old Nov 8, 2009 | 12:44 PM
WW7's Avatar
WW7
Auto X ray is probably the best until you get into the pro scanners costing thousands..I have the Auto Xray 6000 which is around $350.00 but the less expensive ones also do a good job with readings..Just make sure the one you buy does OBD 1 and OBD 2 ..WW
Old Nov 8, 2009 | 12:45 PM
jimg's'93's Avatar
jimg's'93
Check with Chastity Bono. I hear she's looking at gender changers too.
Old Nov 8, 2009 | 03:09 PM
Bulldog Steve
Thanks,
Are there any laptop programs that do the same thing.
That are easy to use?
Steve
Old Nov 8, 2009 | 09:19 PM
joe3906's Avatar
joe3906
Originally Posted by Bulldog Steve
Thanks,
Steve
I use Auto Tap. If you have a good lap top, the program is pretty easy to use. Just punch in: www.autotap.com
and read the info; good luck.
Joe B.
To Need scanner info
