Fuel Line Question
Old Nov 8, 2009 | 05:55 PM
ol school's Avatar
ol school
Default Fuel Line Question
Okay Guys ,
Question , i know i can check fuel pressure thru my gauge but i want to SEE the actual fuel being pumped out , which line will the fuel come out of?
The one that goes to the regulator or the one with the pressure valve???
Old Nov 8, 2009 | 06:56 PM
rodj's Avatar
rodj
If you just want to see fuel coming out then disconnect the supply line (one with valve on it ) ) to rail
Old Nov 8, 2009 | 10:09 PM
ol school's Avatar
ol school
Originally Posted by rodj
if you just want to see fuel coming out then disconnect the supply line (one with valve on it ) ) to rail
thank you
Old Nov 9, 2009 | 07:52 PM
94vettelover2's Avatar
94vettelover2
Okay Guys ,
Also the larger diameter fuel line are almost always the supply line(pressure line).This is true with any car except if the car has a returnless fuel system(only supply line,no return).
Old Nov 10, 2009 | 12:31 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Only on '85-'88, the later cars had the same size lines on both sides.
To Fuel Line Question
