Steering Wheel Click
Old Nov 8, 2009 | 11:32 PM
DSchaefe's Avatar
DSchaefe
Default Steering Wheel Click
I have the dreaded steeing wheel click on my 96 Vert. I have tried tightening and lube to no avail. The click is pronounced and frequent and traced to the U-joint/knuckle on the aluminum steering shaft.
I found the TSBs but have not been able to find the fix. I have searched previous posts but did not learn much. Does anyone know how to fix this? What is involved, parts, etc?
Old Nov 9, 2009 | 09:23 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Is it the shaft or up in the column by the steering wheel?
Old Nov 9, 2009 | 10:12 PM
DSchaefe's Avatar
DSchaefe
I do not believe it is near the steering wheel - I think it is at the knuckle on the aluminum shaft right below the brake master cylinder
Old Nov 9, 2009 | 11:44 PM
the blur's Avatar
the blur
That's called an intermediate shaft, and GM doesn't carry them any more.
Old Nov 10, 2009 | 02:13 AM
enventr's Avatar
enventr
another common problem with the C4 (along with floppy visors and loose door panels etc.) Mine has been clicking for a long time-I have tried all types of lubrication-nothing helps. You will need to find a used part. It is the knuckle. Good Luck
To Steering Wheel Click
