Weird hesitation Problem
Old Nov 9, 2009 | 01:03 PM
davidarnesen's Avatar
davidarnesen
Default Weird hesitation Problem
92 corvette 6sp with 82000 on the clock.
Problem is that when im in a high gear and i step on it it sputters like its misfireing, if i let off of it or accelerate slowly its fine, also if i shift a little later it seems to be ok.
Another weird thing is every now and then ( nothing related to the hessitation) on my dash where it would normally display fuel information or engine temps, i get a flashing 5ys light any ideas on that?
Old Nov 9, 2009 | 04:56 PM
davidarnesen
come on noone not even with an "your opti's diein" comment
Old Nov 9, 2009 | 05:00 PM
lt1396corvette's Avatar
lt1396corvette
Does the engine light come on.Check for codes.Could be a ICM
Old Nov 9, 2009 | 05:34 PM
davidarnesen
no codes at all and no ses light
Old Nov 9, 2009 | 05:45 PM
lt1396corvette
You can take off the ICM and have it tested at like napa or autozone.
Old Nov 9, 2009 | 06:33 PM
davidarnesen
ill give that a shot any other ideas?
Old Nov 9, 2009 | 07:12 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Just replace the ICM and Coil. They go bad, may test ok at autozone but when hot they start to not work so well.
When I replaced mine for the second time in less than a year I took some washers and made an air gap between the head and the ICM/Coil mounting plate. My current setup has been on there about a year and its starting to go bad again.
If it was the opti you would get a code, ICM and coil do NOT throw a code on a 92.
Old Nov 16, 2009 | 01:51 PM
davidarnesen
Just wanted to follow up with you all,
Ended up throwin a 35dollar msd coil in it and that fixed the problem
Old Nov 16, 2009 | 02:26 PM
runner140*'s Avatar
runner140*
And the winner is.....post # 7 (jaa).
The real winner is the Form user.
Old Nov 16, 2009 | 06:15 PM
davidarnesen
hahah yeah you win a used oem coil
To Weird hesitation Problem
