Holy poopie!
Old Feb 27, 2002 | 01:29 AM
Jedi404's Avatar
Jedi404
Default Holy poopie!
I just put on some KYB shocks last weekend(the front, not the back yet), and my car rose! It used to be lowered but its up now, is this normal? Will it go back to normal if I put the backs on? Sorry, I am a little tired and agitated at the moment. Thanks though!
Old Feb 27, 2002 | 01:30 AM
vader86's Avatar
vader86
Default Re: Holy poopie! (Jedi404)
its usually because your original suspension components are worn, nothing to worry about
Old Feb 27, 2002 | 01:33 AM
Jedi404's Avatar
Jedi404
Default Re: Holy poopie! (vader86)
Yeah, but it looked really cool when it was lowered, not I have to buy a lowering kit, lol. :crazy:
Old Feb 27, 2002 | 02:19 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Jedi....did you go and drive the car after you put them on?
if not...you do need to drive it to get them to settle....i put the KYB's on mine and had similar concerns only mine was much worst the tires actually looked cambered inward....(its the independent suspension on the rear).....well after i drove it and got it home...it all settled down to where it was orginally when i had the bilsteins on it.....the KYB's i feel are tough to beat for the bang for the buck.....and i really did not see much difference in ride height....i mean my car sits with a slight rake like every stock c-4 does......but nothing out of the norm....(see my pic to left)
hope this helps..
jeff
[Modified by XtremeVette, 12:20 AM 2/27/2002]
Old Feb 27, 2002 | 02:47 AM
Bill Reid's Avatar
Bill Reid
Default Re: Holy poopie! (XtremeVette)
I have KYB's too... but don't think they hang up the suspension... I don't think any shock could, IMHO...
Old Feb 27, 2002 | 02:50 AM
Jedi404's Avatar
Jedi404
Default Re: Holy poopie! (billreid1@***.net)
Maybe I need to put the backs on? lol, me= :crazy:
Old Feb 27, 2002 | 12:46 PM
GlockLT4's Avatar
GlockLT4
I also have KYB gas adjustables. Go drive them around a bit, i bet it helps.
Old Feb 27, 2002 | 01:38 PM
85 Dave's Avatar
85 Dave
If your old shocks had lost their gas charge, then new ones could raise the car. If the rear shocks lost the gas charge, new shocks will raise it up also.
Old Feb 27, 2002 | 01:40 PM
dtorc4's Avatar
dtorc4
If you ever put your car up on a jack, you will notice that when you lower it, it will sit a little higher until you drive the car. It should settle down some, unless there was something wrong w/ your old shocks. :cheers:
Old Feb 27, 2002 | 04:08 PM
Jedi404's Avatar
Jedi404
Default Re: Holy poopie! (dtorc4)
ttt
To Holy poopie!
