1994 lifter replacement
Old Nov 10, 2009 | 10:18 AM
donkeydawn11's Avatar
donkeydawn11
Default 1994 lifter replacement
Hi everyone
I have a 1994 conv Corvette with about 165K miles.
I have a tapping (ticking) noise comming from the drivers side of my engine seems to be in the area of the last 2 spark plugs.
Can anyone give me step by step instructions on how to replace lifters.
Please feel free and include all advise on this one Im a little hesitant never performed this before.
Old Nov 10, 2009 | 10:25 AM
jimg's'93's Avatar
jimg's'93
Are you entirely sure it's the lifters and not just the injectors you're hearing? I'd use a tube or stethoscope to be sure before ripping into the top end.
On another note: I bought a dd some years back that had a loud ticking (definately lifters) in one of the cylinders. Turned out it was low on oil and was resolved by running CD-2 through the engine several times. NOT that I'm recommending CD-2 for your car!
Old Nov 14, 2009 | 07:30 AM
donkeydawn11
Thanks I will listen to it again
but if it turns out to be a lifter do you know were I can find simple step by step instruction on this forum.
Old Nov 14, 2009 | 08:42 AM
Pete K's Avatar
Pete K
Originally Posted by donkeydawn11
Hi everyone
No one will want to type out a "how to" on lifter replacement. The step by step list is already documented in a service manual. Although I would recommend you purchase a helm's manual, they are expensive. A $12 chilton book at the Pep Boys will tell you what you need to know.
Otherwise, use the search feature to find similar threads. With any luck, there will be pics attached to them.
Old Nov 14, 2009 | 11:14 AM
lt4obsesses's Avatar
lt4obsesses
Using the scope, place it on each injector and rev the engine to 3K or so. Then place the scope on each of the center bolts of the valve cover, reving to 3K or so. Then on the exhaust manifolds, again to 3k or so. You will be trying find the cylinder making the noise. My bad lifter was #5 exhaust. The one thing to look for when you have the lifters out is damage to the cam shaft, as this is why I now have the Hotcam. That stuck lifter had started to wipe out that lobe.
The actual replacement of the lifters is not complicated just teadeous. You will need new intake gaskets, RTV sealant. Make sure you have a system for remember what goes where on the intake and be prepared to replace little plastic vaccum pieces and what not.
Old Nov 14, 2009 | 11:24 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
the valve trains on these cars is quite noisy by nature
Old Nov 16, 2009 | 04:12 AM
VenkmanP's Avatar
VenkmanP
It's basically just take **** apart from the top until you get to the lifters, but if you need handholding, use the relevant parts of the cam r/r instructions here:
http://shbox.com/1/how_tos.html
Nope.
Old Nov 18, 2009 | 08:31 PM
donkeydawn11
Thanks everyone I will let u all know how it works out
To 1994 lifter replacement
