Refridgerant
Old Feb 27, 2002 | 10:25 AM
Jim D's Avatar
Jim D
Default Refridgerant
I have a 93 built in June ,so don't know weather its early or late. Does my 93 use R-12 or 134 thanks Jim
Old Feb 27, 2002 | 11:49 AM
DON M's Avatar
DON M
Default Re: Refridgerant (Jim D)
There should be a sticker under the hood some place. You can tell by the test connections where you hook up the gages. R-12 has 1/4" flare (about 1/2"od)and the R-134a has a much larger one (maybe 3/4"?).
Old Feb 27, 2002 | 12:43 PM
GlockLT4's Avatar
GlockLT4
It should use R-12. I believe 1994 was the first year the automotive industry used R-134a
[Modified by Glock'94, 10:43 AM 2/27/2002]
Old Feb 27, 2002 | 03:14 PM
cajun86's Avatar
cajun86
If it uses R-12 then if you need some extra then you can add freeze 12 which will work with R-12 and you don't have to have a license to buy the stuff and is cheaper than even 134. My mechanic has bought freeze 12 for me in the past and a friend has informed me that you do need a license to purchase freeze 12 so i'm not sure if you do or not now. All in all the freeze 12 is compatible with R-12 and is indeed much cheaper.
[Modified by cajun86, 1:55 PM 2/27/2002]
Old Feb 27, 2002 | 03:53 PM
GlockLT4's Avatar
GlockLT4
Default Re: Refridgerant (cajun86)
:yesnod: :yesnod: :yesnod:
Old Feb 27, 2002 | 09:35 PM
lspalding's Avatar
lspalding
Default Re: Refridgerant (Glock'94)
'94 was the first year for R134. If I'm not mistaken, all of the '94's I've looked at had it. As stated above, it's clearly marked on a sticker on the compressor.
Old Feb 28, 2002 | 06:37 AM
93 ragtop's Avatar
93 ragtop
Default Re: Refridgerant (DON M)
Actually, on automotive R-134 I believe they are all using the Quick connect type fitting. Industries way of making sure we dont confuse them. I know in commerical refrig. they are using a flare fitting which is slightly larger then a standard R-12, R-22 hose fitting.
Old Feb 28, 2002 | 06:57 AM
merrick's Avatar
merrick
I've never heard of "freeze 12". What is that, is that even freon? BTW, Dodge used R-134 in my 93 intrepid.
Old Feb 28, 2002 | 05:11 PM
Jeff M's Avatar
Jeff M
Here's a link:
http://www.refimax.com/home/index.htm
To Refridgerant
