OptiSuck Replacement
Old Feb 27, 2002 | 11:09 AM
Nathan Plemons's Avatar
Nathan Plemons
Default OptiSuck Replacement
Hey guys. There was a thread on here not so long about what other options there were to replace the Opti. Well one of my friends at Holley just got back in town and sent me the list. It has part numbers and estimated prices. Here is the e-mail he sent me
Here is a list of parts they will need to do the swap. They should be
able to leave the factory computer hooked up to use for the speedometer and
mileage.
1. commander 950 system (950-105)
2. hp ignition system (800-100)
3. crank trigger (840-110) The arm will have to be spaced out or a new one
made
4. ati balancer (917271)
Also needed is a piston stop and a coat hanger to make a timing pointer.
This is required to set the timing up. Here are some ideas on pricing
1. 660.00
2. 200.00
3. 185.00
4. 400.00
Keep in mind this are not exact only ideas.
Old Feb 27, 2002 | 11:14 AM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: OptiSuck Replacement (Nathan Plemons)
$1500?? That Opti dosen't sound like such a bad deal after all. :)
Old Feb 27, 2002 | 11:37 AM
Nathan Plemons
Yeah, it's price doesn't seem too bad considering the mileage you typically get out of it.
Old Feb 27, 2002 | 01:53 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
The opti is a great piece as long as you keep it dry. Most people don't have any trouble with them for the first 50-70K miles. That is pretty good for a lifespan of a distributor.
Old Feb 27, 2002 | 08:52 PM
emoshn's Avatar
emoshn
Default Re: OptiSuck Replacement (Vette92)
I agree. Not bad those optis. Mine had 102K on it...still working fine. Pulled it this winter and put in a new one vented. BUT...the old one wasn't THAT bad!! Gonna keep it, put on a new cap/rotor/bearing (for a spare).
Old Feb 27, 2002 | 09:03 PM
bogus's Avatar
bogus
It would be a good investment, if only you did it on the first opti... but gee... I have done mine and I don't wanna spend that much on this thing.
It should improve performance a bit, tho...
I think I was going to race, I would go this way.
To OptiSuck Replacement
