I figured out why so many use the LT4 hotcam
Everything else gets very complicated and expensive in a hurry. Does anyone run this thing with a stock converter and 3.07 gears??? I have surendered in the find the reasonably priced performance cam..LOL Does it work fine with the OEM distributor gear on a L98?
Has anyone runthe 071 ZZ3 cam with the LT$ Hot cam springs and retainers? it is shorter duration and less lift so I can not imagine whay they would not work..
If I go with the Comp Cams XFI part I was looking at I need springs retainers machine heads for more lift.. and add 250 to 300 to the tab even if I do it myself.. That is enough cash to buy rockers and timing chain set. I already have the hot cam springs and retainers brand new on the heads I have...
I am realy not fired up for headers right now and would settle for some good used LT1 exhaust manifolds if they would fit the rest of the L98 exhaust. I have a 2.5 diamiter Y pipe with no cats right now.. If that is any help or clue. The Borla exhaust I have with the magnaflow cat is about all the racket I can stand. I am thinking headers will just add more. If the car does notmake enough power I can add a good set of headers next year.
Intake will be the last thing to figure out and not sure where to go with that..
I picked up a HOT cam for my '88. Those XFI cams are nice but one would have cost me $200 more. Lots of choices on intakes!
Had to laugh when I read your comment about the raket the Borla exhaust and Magnaflow makes. I had magnaflow's with Melrose header, cam, and Rand technology bullet cats; however, I had to get rid of the magnaflows and put my OEM mufflers. What a difference. When driving with the magnaflows, even with the radio at full blast it was awful; do yourself a favor and put OEM mufflers, you won't lose hardly any power, and your wife will get in the car. Good luck.
can't wait to hear how it works
You lose 35hp with stock mufflers. Or, you gain 35hp if you remove the stock mufflers. That is over an open exhaust. After market mufflers have cost as little as 3-5hp up to 50hp depending on the noise level you can stand. This was from dyno testing on 1989 L-98 in the 1990's. Times do change.
Finally settled on cam and going with the 071 zz3/zz4 cam with 1.6 intake rockers and 1.5 exh gives me .506/510 lift. I played around onthe GMPP website with their little dyno program. I did make an assumption that what they offer for combinations and these no doubt have been tested previously so not really a dyno program but just picking one of a few tested combos. This cam is stronger to 3500 even until just before peak torgue and down 10 hp at 5800 but has more area under the curve and more friendly for a stock converter than the LT4 hotcam from what I can see plus can use springs and retainers i have already on the Fastburn heads compared to all the Comp cams stuff that adds 250 to 300 to it all. Seems like a fair trade to me.
Now down to intake choices..sigh..A First seems like big bucks others seem like a lot of work so TBD..
As a side note compared to a TPI the ZZ4 with a carb is +100 hp and + 50 ft/lbs the fastburn heads add 50 more hp and cut the torgue by 3 or 4 ft/lbs with the same cam according to GM.. These are flywheel numbers and it depends on if GM can be trusted with their test numbers..
http://forums.corvetteforum.com/c4-t...-part-2-a.html
trebor
I called the dealer the stock mufflers are discontinued so can not buy stock as delivered only something sort of like it NAPA or whatever. i had rusted out 'dyno max' noise makers... The Borla stuff fits well , magnaflo does not even come close, but not what I wanted sound wise.. For me a racket when on the fast pedal and well behaved off it would be the best of both worlds.
I am thinking it is very easy to get sucked into the lopey idle big cam sounds cool drives like crap. Also if you follow development the LT4 hotcam was designed around the LT4 mini ram and LT4 gearing I find it hard to believe it translates to an L98 or anything like it.
Best to ask Matt. I think he posted the combo in that thread. IIRC LTR, ported 113's, fresh short block. From what I remember he won regional NASA TTA this year, the ZO6's are classed in that, and on J55 calipers!
