CFI to HSR
Old Nov 15, 2009 | 08:50 PM
qws's Avatar
qws
Default CFI to HSR
Thought maybe I'd post some of this here as well. Most of the information is on SV.
Thought maybe some of you guys might have an interest in this build
The project for the winter is converting my 84 CFI to an HSR
This is going to be a few week long process. It will be updated along the way.
Parts ( this will be updated as this progresses)
HSR and Fuel Rail kit from Holley- (FREE)
92- LT1 Throttle body 52mm rebuilt - $100 (used)
30lb injectors new O-rings and flow tested $80 (used)
Dynamic EFI's EBL/Flash ECM- Already have sent out for the multi-port upgrade ($25)
Throttle Cable Bracket- FREE
LT1 Fuel pump- Adanced Auto ($89)
TPI Knock Sensor
TPS Sensor
Manifold Air Temp Sensor
Will be listing parts numbers and prices shortly
89-Chevy truck small cap distributor and remote coil
88- Grand Prix-(8) fuel injector connectors ($40, includes the distributor/Coil
The CFI ( Actually the X-ram)
Mock up of HSR
Overall Height of the HSR
First Problem, Throttle linkage hits the fuel rail elbow. This is not allow the TB to return all the way. I will have to grind down the inside of the cable guide to allow it to return all the way.
Xram compared to the HSR
HSR sitting in place to start figuring out all the small stuff
Old Nov 15, 2009 | 09:29 PM
383tpimachine's Avatar
383tpimachine
my 85 has a HSR from USM
and love it
how you get a HSR for free?
Old Nov 15, 2009 | 09:41 PM
pologreen1's Avatar
pologreen1
Awesome I have been waiting for this thread. I am glad you are getting to it, can't wait to hear how much quicker it makes your car.
Good Luck
Old Nov 15, 2009 | 09:44 PM
qws's Avatar
qws
and love it
Well its a full size HSR, it was won from holley. I won one of the carbs but didn't have any use for one. They gave me the HSR and fuel rails in place. Nice guys!
I already use the EBL/Flash so driving it with a tunable ecm won't be a problem.
I have a huge bunch of photos and everything thats going on with it at SV in the C4 tech section if you want to read about all the details.
Old Nov 15, 2009 | 10:02 PM
JackDidley's Avatar
JackDidley
Great project. Beats the hell out of going carb. Please keep us updated.
Old Nov 15, 2009 | 10:21 PM
qws's Avatar
qws
Good Luck
I've been gettin anxious to get going on it. I know I've got a couple of more weeks I could drive it but I just can't wait any longer!...
Thanks, I would never go the carb route.
I'm also pulling some other stuff off as well.. so its gonna be a long winter but well worth it in the spring!
Old Nov 15, 2009 | 11:23 PM
383vett's Avatar
383vett
Looks great. Looking forward to hearing your results.
Old Nov 16, 2009 | 01:42 AM
kangi's Avatar
kangi
I know what you mean! I have a work bench full of parts. Damn weather isn't cooperating for us to get our projects done! Looks like an interesting one though...say what are you going to do with that shiny crossfire air cleaner cover? I might know of a cool black '84 that would look sweet with that baby under the hood
Old Nov 16, 2009 | 05:25 AM
qws's Avatar
qws
And my wife knows of a nice Red 84 that can go on as well. I have two so she's gonna get it.
JS292 on the crossfire forum did that for me. Get in touch with him and maybe he can hook you up....
Old Nov 16, 2009 | 10:32 AM
85vette-84vette's Avatar
85vette-84vette
What are you doing ove here trolling?
Old Nov 16, 2009 | 10:43 AM
jhammons01's Avatar
jhammons01
I called it first.......maybe not...but I'd like that thing as well!!
Old Nov 16, 2009 | 12:49 PM
qws's Avatar
qws
yeah you caught me. You must not work...
Old Nov 16, 2009 | 01:14 PM
jeffp1167's Avatar
jeffp1167
The best CFI mod ever!
Old Nov 16, 2009 | 01:27 PM
pr0zac's Avatar
pr0zac
the best cf mod would be restricting your ip address
Old Nov 16, 2009 | 01:33 PM
qws's Avatar
qws
Old Nov 17, 2009 | 02:00 AM
Crepitus's Avatar
Crepitus
Old Nov 17, 2009 | 10:42 AM
qws's Avatar
qws
Just to fill you guys in a bit.
The TB i'm using is a 90 version. So I do have to replace my throttle cable. Already found a used one I think
The TV cable also has to be replace because it isn't long enough, not a big deal. The CFI's cable goes from the left side of the tranny to the center of the intake, so it won't reach the TB. Short by about 8-10 inches.
Fuel lines aren't going to be a problem, just a little bit of re routing and making certain it can handle the extra psi to it. Remember the CFI works on 9-13 psi, the HSR is gonna be closer to 40-45 psi.
I took the used fuel injector connectors I got at the local junkyard and made my own harness. I left the pigtails quite long so I have plenty to work with when I make my final connection.
Since I am using a TB that has the coolant pass through it I had a minor problem. Its in the way of the upper heater hose connection as seen here.
To rectify this problem I cut the IAC housing down to this.
For those of you that wanted to know more about a X ram here you go
Top View
Cover of the plenum removed- notice the unburned fuel on the left side?
Entire plenum removed
I still have a ton more pics so if theres anything you want to see just ask.
To CFI to HSR
Old Nov 17, 2009 | 10:18 PM
qws's Avatar
qws
LOL.. shes around gotta post more pics up for you guys
Old Nov 18, 2009 | 08:21 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Lets keep this thread on topic.........
Old Nov 18, 2009 | 12:18 PM
Rohn's Avatar
Rohn
When I removed my CF manifold and adopted the differing induction system I was able to cut the hard line fuel line right by the AC compresser and utilize two compression fittings to AN pushfit Aeroquip hose and same fittings. Worked well and now on my second upgrade of induction system. All reusable and idiot proof.
