How hard is it to change the starter
Old 11-16-2009, 04:10 PM
skybolt31
skybolt31's Avatar
Default How hard is it to change the starter
I have a 95 automatic that is not starting all the time. The solenoid clicks and if I try enough times, it will start, at least so far. I don't have my FSM here and need to know what is involved in changing the starter out. Most specifically, do I need to disturb the exhaust?
thanks
Old 11-16-2009, 04:48 PM
toptechx6
toptechx6's Avatar
Piece of cake, two bolts, two nuts holding the wires, exhaust should not be an issue. Be sure to disconnect the negative battery cable since the large red wire at the starter is hot at all times and if it shorts out you will regret the experience.
If you want to save some money try checking this guys listing, it may repair your issue for a lot less than a replacement.
http://cgi.ebay.com/ebaymotors/DenSK...Q5fAccessories
Old 11-16-2009, 06:41 PM
skybolt31
skybolt31's Avatar
ok, thanks.
I can't get a new starter until tomorrow morning, so I hope it has two more starts left in it............
Old 11-16-2009, 07:25 PM
reoch999
reoch999's Avatar
Not much different than the starter on the 91 camaro I drove in college, and I changed it out in the dorm parking lot about every 3 months with minimal tools. I should have just put some heat sheild around my headers, but instead I abused the lifetime warranty from auto zone. I could have saved myself a few bike rides across town with a starter in my backpack.
Now the starter on a modular 4.6 liter ford mustang, that's a different story. Ford uses a bolt on the top of the starter that is nearly impossible to get to. I helped my friend out, and I think we ended up using about 4 feet worth of extensions and coming in through the grill....
Old 11-16-2009, 08:10 PM
IRAraid
IRAraid's Avatar
Default 95 LT1 Starter
I changed mine a few years ago and found the outboard bolt difficult to get a socket on. There's precious little space between the cat and starter.
Eventually tried a 1/4" drive long extension and socket (move the socket toward the front of the car, up beside the starter between the starter and cat, then rearward to the bolt). I did put a mild crease in the cat heat shield with the socket extension but no problem.
Also, the wires are easier to remove once the starter is loose and moved forward a little. And removing the cover over the knock sensor helps some.
Be sure to disconnect the battery before you begin - as advised above.
Less than an hour job.
Good luck.
Old 11-16-2009, 08:15 PM
383vett
383vett's Avatar
Received 1,550 Likes on 1,048 Posts
Third warning about disconnecting the battery. Especially if you are wearing a metal watchband. You'll have a free tatoo if you don't.
Old 11-16-2009, 11:43 PM
pcolt94
pcolt94's Avatar
Follow above advice.
Changed mined couple years back on my 94. Yours is basically pretty much the same. I did not have to mess with any exhaust. It did not look like it would come out thru that narrow passage but it does come out. The starter was actually smaller than I had envisioned.
One word of advice. Now is the time to change the fuel filter with the starter removed. You can get in there much easer and have much better access.
Old 11-17-2009, 01:40 AM
86PACER
86PACER's Avatar
Disconnecting the battery is a must. Don't be a dumbazz and forget. Otherwise you'll get a rude awakeking when that hot wire touches the engine block.
Old 11-17-2009, 02:48 AM
JD'S WHITE 93
JD'S WHITE 93's Avatar
Received 1,339 Likes on 675 Posts
Not a big deal. Support the car safely and no problems
Old 11-17-2009, 07:42 AM
Muffin
Support Corvetteforum!
Muffin's Avatar
All of the above. There are more than one wires on the positive lead from the battery. These are the electrical feeds for the car. Make sure all get back on.
Old 11-17-2009, 10:55 AM
skybolt31
skybolt31's Avatar
Thanks everyone for the tips, I am going to pickup the new starter now and hopefully will be all set this afternoon.
Old 11-17-2009, 11:41 AM
joe wilson
joe wilson's Avatar
I think the newer C4 came with a mini-starter..if so that's a big help. I changed my 85 to a mini. Much easier to take in and out; works better too. Not so close to the exhaust.
Old 11-17-2009, 02:26 PM
skybolt31
skybolt31's Avatar
OK, the job is done, one hour and 20 minutes including putting the car on the jack stands and a call from the girlfriend in the middle. A little tricky getting to the short bolt, but no big deal.
I think the starter in this car had been going for a while now, whenever I turned the key to start, there was always a little delay before it started cranking. I figured that there was some computer controlled thing going on there, but in retrospect, it was probably the solenoid dragging, the new one doesn't do that.
Anyway, thanks to everyone for giving me the straight scoop on what I was looking at.
Old 11-17-2009, 03:12 PM
86PACER
86PACER's Avatar
Outstanding.
Old 11-17-2009, 05:03 PM
TravisD
TravisD's Avatar
Last time I R&R'd the starter, I found that a universal socket helped immensely for whichever bolt is the hard ot get one - not a U-joint+socket, but one of the shallow sockets with the integrated U-joint (mine happened to be the Craftsman).
Old 11-18-2009, 06:54 AM
Weav's Vet
Weav's Vet's Avatar
On an auto you may have to bend or push out of the way the transmission cooling lines a little to get it through the small hole to drop it down.
To How hard is it to change the starter
Quick Reply: How hard is it to change the starter
