Code 26 on a 92
Old Feb 27, 2002 | 06:59 PM
emoshn's Avatar
emoshn
Default Code 26 on a 92
I'm getting a code 26 (Quad Driver Circuit 1). Anyone know an easy approach to problem solving on this one?
Old Feb 27, 2002 | 07:12 PM
David-F's Avatar
David-F
Default Re: Code 26 on a 92 (emoshn)
Check fuses first in many cases you will find a blown fuse, I think you to check the purge solenoid is pluges in also the EGR solenoid and last the AIR pump motor relay and it's electric air switching valve. Seeing how the EGR and purge solenoid are on top of the engine I would look there first.
David Fulcher
Old Feb 27, 2002 | 08:41 PM
emoshn's Avatar
emoshn
Default Re: Code 26 on a 92 (David-F)
Old Feb 28, 2002 | 12:30 PM
vettes's Avatar
vettes
Check EGR, Canister Purge and AIR pump relays with a digital Ohm meter. A resistance of less than 18 ohms indicates a bad relay. If OK, potential ECM failure.
To Code 26 on a 92
