Trans Speed Sensor leak
Old Nov 18, 2009 | 05:52 PM
jsls0130's Avatar
jsls0130
Default Trans Speed Sensor leak
Do I need to drain all the trans fluid to change the speed sensor in my 1996 Vette? I've had a slow leak for about 6 mths now and I found where it is coming from, its leaking from the electrical plug on the speed sensor. Its a Automatic. Thanks, John.
Old Nov 18, 2009 | 06:59 PM
rodj's Avatar
rodj
No
Put a tray underneath ; a small amount of fluid will come out when you pull the VSS
Old Nov 18, 2009 | 07:32 PM
TWISTERUP's Avatar
TWISTERUP
That may depend on how the car is jacked/supported. I replaced mine sitting level on a lift and as "rodj" says I lost next to nothing.
Old Nov 18, 2009 | 07:43 PM
jsls0130's Avatar
jsls0130
Thanks, I will pick one up in the morning and replace it.
To Trans Speed Sensor leak
