Engine mods
Old Nov 21, 2009 | 08:26 AM
cshuman's Avatar
cshuman
Default Engine mods
I'm in the process of changing my current system, see below, to a super ram and AFR 195 heads. I will have to change my current self alighing rockers to the regular style. I also want to change the stock roller lifters to new ones for piece of mind, they have 93K on them. I will have to also change the stock pushrods? What would everyone recommend in regards to the pushrods and the lifters?
Old Nov 21, 2009 | 09:37 AM
STL94LT1's Avatar
STL94LT1
LS7 lifters and TrickFlow chromemoly pushrods are the best bang for the buck.
Old Nov 21, 2009 | 11:46 AM
cshuman's Avatar
cshuman
So the LS7 lifters will work with a gen 1 motor (L98)?
Old Nov 21, 2009 | 01:16 PM
STL94LT1's Avatar
STL94LT1
Yes, as long as it's a roller camshaft engine.
Old Nov 22, 2009 | 06:49 AM
cshuman's Avatar
cshuman
Is this the part?
GM PART # 12499225
Old Nov 22, 2009 | 12:05 PM
ddahlgren's Avatar
ddahlgren
Do you know who has the best deal on the lifters?
Old Nov 22, 2009 | 12:14 PM
856SPEED's Avatar
856SPEED
Sounds like a great project.....are you sure you want the super ram over the mini?
Old Nov 22, 2009 | 01:32 PM
cshuman's Avatar
cshuman
Yes. The mini will get a little more HP but less torque, according to the information I've read. I got a good deal on a used one so the over all cost will be less with the super ram. And as usual this will probably grow into a rebuilt tranny, rearend, etc. The motor was freshed up 17K miles ago, but at 93K when you add more power other things may happen.
To Engine mods
