no ohm value on key?!
i have done just about every test you guys have posted about. when i checked the resistance on my key there is no value just OL on my meter. any ideas.
thanks
jason
by "would'nt start', do you mean it cranks but doesn't 'catch', or that it doesn't even crank?
If it does not 'catch' (i.e. while cranking, the engine will NOT start), then your problem lies elsewhere.
If it does NOT crank, then it might be related to the PASS-Key system (key resistor 'read' by ignition switch).
BTW, I'm not sure I understand the results of your testing of the key.
Does "0L" mean 'zero resistance' (i.e. closed circuit with no resistance -- equivalent to touching the tester leads together),
or an open cicuit with infinite resistance (equivalent to NOT touching the tester leads to anything)?
Because, normally resistors fail by creating an open circuit, not by creating zero resistance.
Testing the key's 'resistor' should be done first on the the 'continuity' setting (beeps when leads are touched together or touched to something that has no resistance).
Then on the high resistance (K) setting.
Both are done by touching one test lead to one side of the key's resistor and the other test lead to the other side of the key's resistor (small metal protrusions on either side of the key in the middle of the small black hard plastic insulator material).
Your results should be a 'beep' on the continuity setting and a high resistance on the high 'K' setting, which will equate to one of 15 different resistance values -- each corresponding to a particular key blank (here's Eckler's website link as an example: http://www.ecklers.com/product.asp?p...1&dept_id=1283
thanks
jason
thanks
jason
You did some right moves and got thru it. Now do the next right thing write down the VATS key code number in one of the corvette books you have. And get a spare key and put it in a safe place.
