Kinda stupid question...
Old Nov 23, 2009 | 02:08 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default Kinda stupid question...
I am building a replacement engine on the side as I get money. Right now I am trying to price out a rotating assembly, which because of my race class has to be just like the factory (I am allowed forged internals for longevity and weight savings). What length rod came in a factory L98? 5.7" or 6"? Other than CNC Motorsports who has good deals on balanced rotating assemblies?
Old Nov 23, 2009 | 02:15 PM
engle1147's Avatar
engle1147
5.7"
Old Nov 23, 2009 | 02:26 PM
Pete K's Avatar
Pete K
I recommend seeing your favorite (local if possible) machinest. Let him pick the pieces and check and balance them. The price is usually similar, and you get a better end result.
I just opened a brand new set of Eagle rods, and they are all .001 small. I have to open them up to fix them. By buying the parts from the machinest, he can tweak them to be perfect. As I said, you get more for your money that way.
Old Nov 23, 2009 | 02:39 PM
Aardwolf's Avatar
Aardwolf
Checking around I went with a local race engine builder. He's is making and has made many of the local engines around here. As above stock is 5.7", consider a 6" or 6.125". Pay close attention to the dynamic compression ratio.
Old Nov 23, 2009 | 03:25 PM
Kubs's Avatar
Kubs
Thanks guys. They guy who did my dad's 400 block also checked clearance and such. His prices werent bad.
Ill have to check the rule book but I dont know if I can go to a 6" rod.
Old Nov 23, 2009 | 03:34 PM
neat's Avatar
neat
I've had good luck with www.flatlanderracing.com
Local is always a good option as well.
Old Nov 24, 2009 | 09:35 AM
CFI-EFI's Avatar
CFI-EFI
I thought that was the whole point of the thread. That you HAD to use the factory length rods.
RACE ON!!!
Old Nov 24, 2009 | 10:03 AM
Kubs's Avatar
Kubs
RACE ON!!!
I am mostly sure but I am allowed things like forged instead of cast and Im allowed .5 increase in compression and less than 1.5% increase in displacement. It might in there somewhere.
To Kinda stupid question...
