front accessory brackets
Old Nov 23, 2009 | 09:43 PM
Chrisjenson9478's Avatar
Chrisjenson9478
Default front accessory brackets
just finishing up my 383 build when I went to mount the front accessory bracket and realised the bracket on the passenger side wont bolt up. the problem is the cylinder head doesn't have one the upper bolt hole tapped out its the one closes to the intake. is there something I can do? please help
Old Nov 23, 2009 | 11:51 PM
383vett's Avatar
383vett
Drill and tap a 3/8" hole. If you have a good eye and guts, try it in the car with the heads on.
Old Nov 24, 2009 | 11:39 AM
94vettelover2's Avatar
94vettelover2
Thats scary.How many bolt holes are there to mount bracket?If you have a bolt hole above & below that missing hole you should be fine.I personally would not drill into head
Old Nov 24, 2009 | 11:48 AM
Chrisjenson9478
I don't know if I wont to risk a head on a maybe, but lets say I did are you talking 3/8th in depth.
Old Nov 24, 2009 | 11:50 AM
Chrisjenson9478
would just having two bolt really do the job your would the torque from the engine cause the bracket to rock back and forth
Old Nov 24, 2009 | 11:52 AM
Pete K's Avatar
Pete K
There is no maybe. This is kids stuff.
It is a piece of cast iron. Drill it, tap it and be done.
Thats what they do when they make blocks and heads.
Old Nov 24, 2009 | 11:53 AM
Pete K's Avatar
Pete K
Try it and see. If it snaps off, you will know.
GM put the holes there in the later years to accomidate the modern brackets. If they engineered for it, they likely need to be there.
Old Nov 24, 2009 | 04:27 PM
rodj's Avatar
rodj
88+ L98's are known for cracking the A/c bracket with all the bolts installed , especially if the braces are left off
To front accessory brackets
