fuel injectors help please
Old Nov 24, 2009 | 11:17 AM
imdaking06's Avatar
imdaking06
Default fuel injectors help please
i have a stock 91 l98 i want to put accel fuel inejectors do i have to make any changes to my fuel pump? please help
Old Nov 24, 2009 | 12:18 PM
BobRR3's Avatar
BobRR3
you better know what you're doing before you change your injectors. If you plan on using injectors with a flow rate other than stock, Youw ill need to reprogra your computer. The best thing you can do, Is to contact Jon @ FCI He will steer you in the right direction.
He is the resident expert on Fuel injectors.
Old Nov 24, 2009 | 12:29 PM
engle1147's Avatar
engle1147
FIC Injectors :http://forums.corvetteforum.com/memb...injectors.html
Old Nov 24, 2009 | 02:01 PM
neat's Avatar
neat
You don't need to change anything with the pump or regulator. If you have bad injectors, and you plan to keep the car stock, a fresh set of stockers from FIC is probably the way to go. If you plan to mod extensively, a larger set might be the best choice but be prepared to tackle the hurdle of tuning the computer.
To fuel injectors help please
