Coolant problem
Old Nov 24, 2009 | 06:33 PM
VetteTheWorld's Avatar
VetteTheWorld
Default Coolant problem
I drained the coolant out of my 91 Coupe and flushed the system. I also replaced the thermostat. When fillling it up with the coolant I am supposed to put in almost 4 gallons of liquid but I can only get 2 into the system even after running it for fifteen minutes. Has anyone experianced this problem before? How should I solve this? Currently the Vette is running at about 180 degrees. Is this about what everyone else is running at?
Old Nov 24, 2009 | 08:28 PM
devildog's Avatar
devildog
From: fighter pilots make movies, bomber pilots make history
Henry,
You have to remove the NPT drain plugs (Knock sensors if LT-1) on the sides of block under the exhaust manifold to drain more fluid. Some fluid remains in the block unless you pull the plugs or sensors.
If you flushed long enough to get get clear water, you got the bad stuff out. It is really not need to pull those plugs or knock.
If you refilled with 100% glycol coolant, you are about 50/50 glycol/water. If you refilled with two gallons of pre-diluted coolant mix which is 50/50, you have about 25% glycol coolant which is OK. It is not going to get cold enough in SC to need lower freeze protection than 25% glycol concentration.
Enjoy the Vette, drive safe
Joe
Old Nov 24, 2009 | 08:30 PM
383vett's Avatar
383vett
Did you drain the block? When I fill my motor and radiator with no water in the block, I think it takes 2-3 gallons, but I have an '84.
Old Nov 25, 2009 | 10:35 AM
azrocketman's Avatar
azrocketman
I only drained about 9 quarts of coolant from my '86 after draining the radiator and removing the driver's side drain plug. Never did find the drain plug on the passenger side (is removing the knock sensor the answer?). Cooling system capacity is supposed to be 17 quarts according to the owners manual.
Steve
Old Nov 25, 2009 | 11:16 AM
CFI-EFI's Avatar
CFI-EFI
And everyone knows the 1984 Crossfire block is unique. The FSM lists the coolant capacity at 14.5 to 14.8 quarts, just short of 4 gallons. Could the optional oil cooler boost it beyond 16 quarts?
Steve
That seems like an awful lot. Can the cooler add that much? The Gen I engines have the knock sensor(s) mounted in the block coolant drain hole(s).
RACE ON!!!
Old Nov 25, 2009 | 02:32 PM
VetteTheWorld
Originally Posted by devildog
Henry,
Joe
Great information. What does NPT stand for? What does this drain plug look like? Any more specific information on the location of the plug?
Old Nov 25, 2009 | 03:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
NPT=National Pipe Thread
On the bottom center of block, both sides, is where you drain the block. Pass side will have a knock sensor in the hole, drivers side will have a plug or nipple for cooler hose.
Old Nov 25, 2009 | 03:36 PM
SunCr's Avatar
SunCr
There are no pipe plugs on the '91 (except the left head, but that will only drain the left head). You can remove the oil cooler hose at the filter (left side) and the Knock Sensor right side or you can try pulling the lower hose with nose pointed downhill.
Old Nov 25, 2009 | 05:20 PM
MK 82's Avatar
MK 82
Consider your self lucky. I just changed the coolant in my RV.
10 gals of coolant and 8 gals of oil.
4 gals in the diff.
Old Nov 26, 2009 | 08:38 PM
devildog's Avatar
devildog
Henry,
Suggestion for you, buy the FSM (field service manual) for your 91. They are a bit pricey, but you will save the cost many times over when you need to service or repair your 91.
They are thick about 3 inches, but have all the diagnostics, wiring diagrams, component locations, etc.
continue to ask questions on this forum, good guys and gals that will want to help you. But, with big, official service manual you can ask better questions and understand the answers in a more meaningful way.
A good gift for Christmas. Maybe someone will chime in and tell you where to order the FSM.
If you race that thing, take it to the track.
Joe
Old Nov 27, 2009 | 07:43 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
FYI, if you were adding pure anti-freeze, and presuming you flushed by also running the engine, not being able to add the correct amount also means your coolant system is NOT properly protected.
One other technique (aside of the block draining) that has worked for many is to use a shop vac on 'blow' mode and apply it to the 'surge tank' if so equipped (black tank by windshield). This has successfully pushed-out all of the coolant for many.
ALso, be sure the heat for inside the car is 'turned on', as some years has a valve which prevented coolant draining/exchange from the heater-core if closed.
To Coolant problem
