While driving my new acquisition home (1984 cfi auto 104k miles) I was sitting @ a traffic light and the temp crept up to 225 deg before the light turned green. While underway it stayed stone cold @ 196. Is 225 okay? It seems too hot, but a few threads have mentioned that their fan does not kick on until 227-230.
Thats normal but I don't like it so I installed a manual fan switch on mine.Easy install and 16 bucks thru most corvette magizines
I have picks of my job during install
I have built a couple of hot rods and used a universal fan temp switch. It costs only 20.00 at the auto stores. It is adjustable and comes with a relay. Maybe I'll add one of those bc it seems too hot to me as well.
From: Appleton, Wisconsin Boston originally - North End
I started these threads a couple weeks after I bought my '84 in July and was concerned about operating temps - EXACTLY what happenned to you motorjunkie.
The stock fan on temp for your 1984 is 238°, off is approx 225°. GM says to shut it down when you see 260°. That is hotter than I prefer. If you need an adjustable temp switch the item from Jegs ought to be fine. You already have a fan relay, so you would be buying something you already have. The 1984 is unique in that the ECM plays no role in the fan operation. I am sure any Corvette specialist would be happy to sell you a manual switch for $16.00 or more. Any SPST toggle switch available at any auto parts store or Radio Shack for a couple of bucks will work as well.
Another idea is a lower temp fan switch, but there is no need for an expensive "kit". A switch can be had at any auto parts store for ~$10.00. A word of caution, especially with the stock 195° thermostat, be careful to avoid a switch with too low of a fan "Off" temp. If the switch will shut the fan off at 185° for instance, the engine will never cool to the cut off temp and cause the fan to run constantly once it starts. That is a waste of gasoline, fan motor life, and an annoyance. Regardless of the stat, a 185° fan off temp is too low. You don't need a fan at that low a temp.
Thanks everyone. I was not aware that the ecm did not control the fan on 84 models. My oil temp is higher than the coolant. if my coolant is 196 cruising then my oil temp says it is 230. Is this correct?
It may be a good idea for you to perform some preventative maintenance to the Cooling system.
I also have an '84 and after I took care of all the cooling components, my car never saw those types of temps again. Even on 90° + days in stop and go traffic (only gets to about 219°
My situation was extreme due to the Water pump failing and then the radiator splitting...but after I replace all those components the temps were fantastic afterward.
I'll not suggest changing the WP, but I would say to flush the system and pull the radiator and have it boiled out at a shop.
Plus if you pull the radiator, you'll see tons of trash in between the condenser and radiator.....that is a 6-8 month cleaning item.....Cut your radiator shroud when you have it off. You are cutting it so that next time you can remove it in a way whereas you don't need to take the hoses off in order to lift the shroud.......makes the job as simple as taking out the ~20 screws that hold in place.
Maintenance is the key to keeping the cooling system working at it's full capacity. If you are cruising down the highway at 196° with the stock 195° stat, your cooling system seems to be working well. My guess is that the boiling out of the radiator may not be needed, but since the car is new to you, pulling the radiator to check for debris, and to clean out from between the radiator and the condenser is an excellent suggestion. You may be surprised at what you find. Air flow is the key to keeping the coolant temps under control. With the debris removed, air flow at about 30-35 mph should keep your temps in line. In stop & go traffic and at stop lights, the fan will keep the temps in check if the cooling system is in good shape. I flush my my cooling system and change my antifreeze every two to three years max. And when I flush, I spend a lot of time and do a super thorough job.
My oil temp will usually run 230° - 235° once completely warmed up.
