Motor Mounts
Thanks for the info.
They are listed as a left and I believe I used 2 lefts. It's been awhile since I did this, so I'll have to double check. I should be able to go through everything by tomorrow and post back for you.
Summit etc. sells them, link to pic/details:
http://www.energysuspensionparts.com...FRDxDAodgTh0nQ
Not sure what kind of data I could provide. My logic is that a fresh poly insert is better than the 15 year old visibly sagging (when removed) rubber ones on my car. I never bothered taking pictures of this mod. I can only say that it is fairly easy job.
When rebuilding the "clam shell" style motor mounts, you will first drill out the eyelet/rivet that holds both parts of the clam shell together.
Remove stock rubber inserts by separating clams using a large screw diver or small pry bar. If the rubber ones are "stuck" to one side of the steel clam, a propane torch serves to persuade the old inserts out.
Next, clean clam halves (now is the time to re-paint/coat) and replace w/the new inserts, making sure that the direction of the new insert matches the form of the steel clam (as the front and back have a different male/female pattern).
Re-assembly is done by using the new grade 8 studs/with locks/and washers to attach both halves of the clam shells together. I chose to use some 'lock-tite' (blue) on the threads for extra insurance. When finished tightening down the new fasteners, the mounts are ready to re-install on the block. Fitments on mine was excellent and I had zero issues.
This year however I will be pulling those in favor of the solid ones I have.
you might want to reconsider going to solid mounts. I went to solid mounts on my 90 camaro (unibody construction) and the vibration transmitted into the cabin is quite a bit. i thought something was wrong with my AC compressor when it cycled on and replaced it, then discovered replacement had just as much vibration & noise, so it was normal. just that now I was hearing it. like having the feeds from the auto stethoscope fed into the interior.
on my C3 with motor mounts, since it's a perimeter frame car, with the body insulated from the frame, not a problem, the body mount bushings isolate the NVH.
however, after a while, i got used to the "surround sound audio" in my IROC. did consider switching to poly-U mounts, even went out and bought them, but then changed my mind and decided i'd rather live with the audio. my radio doesn't work anyways.
but it was a shock since i had done my C3 first and that was fine, but the 90 F-body was a totally different experience. the C4 is also unibody construction.
just my 2 cents.
