Which coolant to use?
Old Feb 28, 2002 | 04:10 PM
emoshn's Avatar
emoshn
Default Which coolant to use?
I have a 92 LT1. My system is partially drained (for other work). I'm installing all new hoses. The coolant is currently green (Prestone?). I want to flush her out and replace the coolant. Which coolant is recommended. Is Prestone Okay?
I don't have a cooling problem anymore since going to 160 stat...so that isn't an issue.
Old Feb 28, 2002 | 04:20 PM
GlockLT4's Avatar
GlockLT4
Default Re: Which coolant to use? (emoshn)
yep, just use good old green stuff as replacement.
Old Feb 28, 2002 | 04:31 PM
Nathan Plemons's Avatar
Nathan Plemons
Any of the green stuff should be cool. I think there are some issues with the water pump seal or something if you mix the orange with the green, or use the orange in a system that had the green previously even if it's been flushed.
Personally I flushed my entire system and installed an electric water pump. When I had it all flushed out, and I mean ALL flushed out I put in the orange stuff because it's supposed to last longer.
Old Feb 28, 2002 | 04:33 PM
GlockLT4's Avatar
GlockLT4
Default Re: Which coolant to use? (Nathan Plemons)
hmm.. according to GM you're not supposed to put Dexcool into anything but 94-96's. The 96's came with it but 94-95 could take it without problems.
Old Feb 28, 2002 | 05:10 PM
Shylor's Avatar
Shylor
The orange stuff is silicate free coolant. The silicates are what caused water pump bearing failures. That is why they went to this type of coolant.
Old Feb 28, 2002 | 05:19 PM
RadPolo96's Avatar
RadPolo96
Default Re: Which coolant to use? (Shylor)
Yup I already had to replace waterpump and now im doing radiator. Fun stuff :rolleyes: . Gotta love dexcool.
Old Feb 28, 2002 | 05:37 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Which coolant to use? (RadPolo96)
Hey.... My '95 has some brownish sludge looking stuff in the recovery tank (low side), dealership said something about "dexcool" this or that when I mentioned it. 28,000 miles and planning a coolant flush and refill soon, I understand it is due at 30,000 miles. I *DID* bring the recovery tank level up a bit by putting in some green stuff. Before putting it in, though, I made sure to check what color stuff was already being used by the system and it was green also (peeked into the high side recovery tank when the car was cold) :chevy
Old Feb 28, 2002 | 05:42 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I vote green! Prestone is one brand. I use dionised H20 in last flush and mix with the coolant.
Ethlyene Glycol with silicate inhibitor package. 50/50 H20 is standard. Less EG and more H20 = better cooling but reduced corosion protection. I would'nt go below 40% EG without some additional inhibitor additive, especially with new parts in the mix.
Old Feb 28, 2002 | 05:49 PM
emoshn's Avatar
emoshn
Default Re: Which coolant to use? (PeteL)
Of course up here (alaska) we use it in everything...but we call it antifreeze. And we run 50/50 or 60/40 antifreeze/water. Even though I don't drive the vette in the winter, it will probably be stored outside. This year I had a few things I wanted to do to her, so she's been in a heated attached garage for about 5 months now.
I'm gonna have to clean the inside of the windshield from going "Brruuummm, Bruuummmm!" while I sit in it. :D :lol:
Old Mar 1, 2002 | 01:04 AM
yellavette94's Avatar
yellavette94
Did 94's come with dexcool?
Old Mar 1, 2002 | 03:14 AM
Bgreenard's Avatar
Bgreenard
Go Fast
Default Re: Which coolant to use? (yellavette94)
I've been running the green Prestone 20% mix with Redline Water Wetter to keep the temp down, never had a problem.
B
Old Mar 1, 2002 | 03:25 AM
vetsvette's Avatar
vetsvette
Default Re: Which coolant to use? (Bgreenard)
Mine came with Dexcool and thats what I continue to run. I flush and replace it every two years. Another good thing about Dexcool is if your dog slurps some of this he won't throw up and die under your car. :U
[Modified by vetsvette, 2:26 AM 3/1/2002]
Old Mar 1, 2002 | 08:50 AM
PeteL's Avatar
PeteL
Default Re: Which coolant to use? (vetsvette)
DexCool is just as dangerous and posionous as the green. Both are ethelyne glycol based. Both smell and taste "sweet" .
There is an anti-freeze that is supposed to be safe, I think it is propolene-gylcol based, but not sure at all about this. Heard it is still posionous, but takes a lot more to do the damage.
GM started using DexCool in 96, but it seems some 95's have the stuff. It is not recommended by GM for pre 94 engines. It is a GM formula that they license to manufacturers; Texaco was first to get approved, believe Prestone also now has a DexCool stamped coolant available.
Old Mar 1, 2002 | 09:55 AM
Thud's Avatar
Thud
Default Re: Which coolant to use? (Glock'94)
Shouldn't make a difference... how is a '94 cooling system different from a '93 or '92?
Old Mar 1, 2002 | 10:37 AM
Nathan Plemons
Default Re: Which coolant to use? (Thud)
Exactly. It's a matter of the seals and such. If you completely flush your system you are fine putting Dex-Cool back in it.
Old Mar 1, 2002 | 11:18 AM
PeteL's Avatar
PeteL
GM put out a TSB last year that says not to use DexCool in pre - 94 cars. It is posted somewhere in the archieves of this section. I can probably find it again on my HD if need be.
Personally I believe that there are more than seal issues involved: gaskets, areas of cavitation, % air in cooling system, presure cap spring loaded vacuum release valves, other issues. This is a personal opinion.
Old Mar 1, 2002 | 11:21 AM
Nathan Plemons
I can't say what it does if you put it in something that hasn't been completely flushed out. I can say that I've been running it in my 92 with electric water pump for 10k miles without any problems.
There might be more things involved but I'm pretty sure I remember reading about the seal in the water pump being real important. The electric pump eliminates that seal.
To Which coolant to use?
Old Mar 1, 2002 | 11:39 AM
PeteL's Avatar
PeteL
Honestly don't have enough "fact" on DexCool, it very hard to get the "facts".
I would stick to a two year flush cycle, check pH regularly (if below 6 flush), and flush if any air gets into the system (even from litttle tiny leaks like the radiator cap). I would also run a 50/50 mix only and not use additives. This again just personal opinion, but based upon what I have read and heard only.
I see little advantage to changing a "green" system to DexCool. Recommended flush cycles revert to 2 years, regardless of the quality of flush. Silicates will still be present in the system, with no way to prevent. DexCool offers no cooling advantage over green and costs more, so that's where I am on it.
Old Mar 1, 2002 | 03:04 PM
GlockLT4's Avatar
GlockLT4
nope...
Old Mar 1, 2002 | 03:05 PM
GlockLT4's Avatar
GlockLT4
taste "sweet" .
And you know this because?!?!? :jester :crazy:
