Too Many Codes
Old Mar 1, 2002 | 08:44 AM
DI2FLY's Avatar
DI2FLY
Default Too Many Codes
Please go to C5 tech area and find my post, since I put it in the wrong place.
Same title, about codes frustration.
I really need your help.
Thanks :smash:
Old Mar 1, 2002 | 11:38 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Too Many Codes (DI2FLY)
http://forums.corvetteforum.com/zerothread?id=248056
Hmmm.. My local Chevy parts guy told me that the relays were the same. If not then that could be why mine sets a code 33 twice a year. If I change the relays it runs great but eventually I will get a code 33.
:confused:
[Modified by War Machine, 9:39 AM 3/1/2002]
Old Mar 1, 2002 | 11:56 AM
David-F's Avatar
David-F
Default Re: Too Many Codes (War Machine)
They are the same on 87 to 89 only 86 had two different relays and for some reason it does make a difference.
David Fulcher
Old Mar 1, 2002 | 12:00 PM
War Machine
Default Re: Too Many Codes (David-F)
Whew Thanks!! :cheers:
Old Mar 1, 2002 | 01:39 PM
David-F's Avatar
David-F
Here is a copy of the bulletin with the one relay part number. Document ID # 270072
SERVICE ENGINE LIGHT-CODE 33 NEW P/N MAF POWER RELAY #86-152
MODEL AND YEAR: 1986 CAMARO WITH LB9 ENGINE (ENG. CODE F) 1986 CORVETTE WITH L98 ENGINE (ENG. CODE 8)
Some 1986 Camaros and Corvettes with port fuel engines may experience complaints of service engine soon light and poor driveability. If this condition occurs and a code 33 is found stored in the ECM, the following steps should be taken.
1. Perform diagnostic check for Code 33 found in your 1986 Shop Manual (Section 6E3).
2. If Code 33 is intermittent it will be necessary to change the MAF power relay. The MAF power relay new P/N is 10067925.
NOTICE: CARE MUST BE TAKEN TO CHANGE THE CORRECT RELAY. REFER TO ILLUSTRATIONS.
David Fulcher
Old Mar 1, 2002 | 09:48 PM
DI2FLY's Avatar
DI2FLY
This is not an intermittent problem. The only tipoff is the ses light. The car runs perfectly from idle right to redline. And all affected systems described in previous threads work fine as well.. That's what bugs me.
I did change both relays on the firewall behind the battery. Visual inspection of all terminals show no dirt or damage. MAF unit and connections check out as well.
BTW I'm actively looking to trade this thing in for a C5 as soon as I see one I want. Could be any day. I'm just afraid I won't be able to unload it with a SES light on. After 13 years with this car, it's time to part ways.... :seeya
To Too Many Codes
