Sway bar end links
Old Dec 5, 2009 | 02:56 PM
illenema's Avatar
illenema
Default Sway bar end links
My bushings are bad on the rear sway bar.
I got energy replacements. I got them forced into the bar itself, but I be dammed if I can get the new bushings forced into the endlinks. Anybody done this?
Old Dec 5, 2009 | 03:06 PM
94z07fx3's Avatar
94z07fx3
how far off are they?
If you were to put the new bushings into a cooler with dry ice (-40) and the end links into a warm oven say 270*F would that make enough of a difference?
Old Dec 5, 2009 | 04:05 PM
illenema's Avatar
illenema
So the cold would shrink the bushings enough to help.
I got the bushings in the bars by using a vise to push the bushing threw.
It got in there about 1/2 and had to force the starting of the other 1/2 with a screwdriver. Then when in the new metal sleeves had to be forced in again with the vise and almost tore the new bushings.
All in all dog**** energy bushings.
Old Dec 5, 2009 | 08:08 PM
IRAraid's Avatar
IRAraid
Default Sway bar end link bushings
I used a long bolt, washers, nut and a socket arranged like a sleeve puller/installer to put the bushings in. Lots of lube too. Really a pita. After they were in, it really quietened the ride. Well worth all of the effort.
Old Dec 5, 2009 | 09:02 PM
StealthLT4's Avatar
StealthLT4
Not sure if the rear end link is similar to the front, but I had the same problem. Just bent the 'sheet metal' end link a little bit more open so I could slip the sway bar in. Then tightening the bolt pulled it back tight.
Old Dec 5, 2009 | 09:03 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I've done this twice and you need a vice. Take your time, grease them, take your time, take a break. They do fit.
To Sway bar end links
