Reverse Lockout
Old Dec 6, 2009 | 11:23 PM
grantar2's Avatar
grantar2
Default Reverse Lockout
Ok, having transmission issue. Box is running well, however the clutch slave died and needed replacing. Fixed that, now teh the reverse lockout switch or whatever you want to call the unit you have to pull up on to put the ZF6 in reverse has broken. The issue at hand is two fold, do I chase down the part and repair it, or do I replace it with a HURST which eliminates lockout all togehter I am told. From what I have read don't feel a B&M is the right fit for me. I am not a fan of the hurst shifter ball in my 90. Was ok in the 69 GTX but looks odd in a corvettes' interior.
Your thoughts are appreciated.
Old Dec 7, 2009 | 01:19 AM
94z07fx3's Avatar
94z07fx3
If you do go the replacement route, call ZF Doc and see if he can hook you up with a 1996 MY variant shifter which has no lock out but rather crash-thu reverse protection.
You may be able to eyeball it and repair yours if you remove the center console bezel details for that are in the C4 Audio FAQ.
Old Dec 7, 2009 | 06:19 AM
mazdaverx7's Avatar
mazdaverx7
how has the unit broken? what is it not alowing you to do?
Old Dec 7, 2009 | 11:15 AM
grantar2's Avatar
grantar2
The plastic collar ring you pull up on has disconnected and is just sliding up and down the shaft.
Old Dec 7, 2009 | 01:38 PM
Scrrem's Avatar
Scrrem
Mine did the same thing. With mine, there is a little hex set screw that came loose which locks in that collar. If your happy with the present shifter, it may be worth taking it apart and checking that hex screw. I swapped mine for a Hurst and love it. Could stand the reverse lockout function.
Scrrem
Old Dec 7, 2009 | 06:51 PM
STL94LT1's Avatar
STL94LT1
Get the Hurst and use your factory shift ****. The Hurst is one of my favorite mods and I've done quite a few.
To Reverse Lockout
