Engine rebuild/upgrade project
Old Mar 3, 2010 | 06:02 AM
Sliding's Avatar
Sliding
That orange color was too much for me, so I cleaned it all
off and repainted it.
So the block is bored/honed, zero decked, new cam bearings
and freeze plugs are installed.
Just one more final cleaning and it's ready for assembling.
Old Mar 29, 2010 | 04:34 PM
Sliding's Avatar
Sliding
Did some work last few days
Here are "a few" pics
crank balanced and polished
new ARP main bolts
crank in place and all mains measured with plastigauge
all mains are cleaned of plastigauge and lubed
checking crank end play
rings file fitted and measured for correct gap
new SCAT forged rods and Clevite rod bearings
plastigauged all rod journals
rods, pistons, rings assemblies
rotating assembly done
new (CC HR288) vs old (LPE 219) cams
cam and timing set are in
new LS lifters
That's it for now!
Old May 12, 2010 | 03:01 PM
Sliding's Avatar
Sliding
Update.............
I've finally found some time to finish the heads.
New bronze valve guides are in and cut for .530" seals
Valve spring seats are cut for larger springs and to exact
height
New seals, valves, springs, Ti retainers...
Old May 12, 2010 | 10:58 PM
96GS#007's Avatar
96GS#007
Good progress Do you have a date in mind regarding installation and start up?
Old May 12, 2010 | 11:55 PM
BLOCKMAN's Avatar
BLOCKMAN
Is the cam your using on the left as it looks like a cast core rather then a billet cam core!!
Old May 13, 2010 | 03:32 AM
LD85's Avatar
LD85
Very nice work an attention to detail!
Old May 13, 2010 | 06:14 AM
Sliding's Avatar
Sliding
Thanks guys!
I hope that I'll have the car ready in about a month or so. I still have
some porting to do on the intake and finish the assembling.
The cam is a used CC XR288HR. I believe that it is cast cam.
Do you think that this could be the problem?
Thanks!
Old May 13, 2010 | 07:03 AM
EastCoastHD's Avatar
EastCoastHD
Fantastic work on the heads. Would love to see the flow #'s
Old May 13, 2010 | 08:36 AM
BLOCKMAN's Avatar
BLOCKMAN
Originally Posted by Sliding
Thanks guys!
With the bigger springs your using I would not go with a cast cam core as I have seen on the WWW their have been some issues using them.
Seeing your going to bigger springs make sure you are using a performance cam bearing and not a stock replacement cam bearing or you flatten a stock cam bearing cause they are softer then the performance cam bearing.
Old May 13, 2010 | 09:02 AM
Sliding's Avatar
Sliding
I have clevite cam bearings installed.
I was unaware of cast cams issues but i don't
have the time or money to change now. I guess that i'll have
to check the valvetrain more often.
Thanks for the heads up.
Old May 13, 2010 | 10:41 AM
BLOCKMAN's Avatar
BLOCKMAN
Which clevite cam bearings?? If they are the sh-290's they are to soft and if they are the 1349's I have had calls on issues spining the cam bearings on start up.
Had a shop right near me spin cam bearings on 2 engines in a row on the dyno!!
Becarefull!!!!!!!!!!!!
Old May 13, 2010 | 10:50 AM
BLOCKMAN's Avatar
BLOCKMAN
Cast cam cores
Z15CAM11-10-2006, 08:50 PM
I'm Posting to add some INFO or perhaps a WARNING Re; Com CAMS Cast Hardened Lobe Treated Roller.
I was browsing around at Team Chevelle Site and came across this Thread: http://www.chevelles.com/forums/show...ller+cast+core
Re: Comp CAMS Cast Rollers Vs Billet Camshafts and its got me concerned. I for one thing I just realized the cam I'm running now is Cast and not a Billet. I am running a Cast Roller with Crower Hippo Oilers. Seems there have been allot of Failures reported with these cams probably because the purchaser was not aware that the Roller they purchased was NOT a Billet.
From what I can deciphered from the thread is that the Cast Rollers can not handle high Spring Seat Pressure and Rates that the Billet Shafts can handle with the same Profile. Therefore; it is understood that, your RPM must be limited or you’re inviting trouble. Consider MAX RPM of 6200. Seems Comp CAMS does not recommend a Seat Pressure over 169lbs and a Rate not higher then say 496lbs (which is too high by opinion) conducive to their 929-16 & 953-16 Spring Packages for Cast Rollers; where as, Billet Shafts can handle considerably more pressures with the same Lobe Profile and can maintain 7000+rpm.
If you have mind to hit 7000rpm and hold it there with your BBC I understand that a REAL Comp CAMS Tech will recommend you order a Special Grind Billet with the same Lobe Profile as the Cast Roller Shaft and specify they install the CAST Distributor Gear so you will not have to use Bronze or expensive composite Distributer Gears. The Tech will recommend the appropriate springs that have much higher Seat and Rate Pressures. Unfortunately for me I must not have been talking to a REAL Comp CAMS Tech as he did not make the above recommendations when I ordered the CAM.
Comp CAMS CAST Roller Camshafts can be identified buy there part number ending with the # “8â€. Comp CAMS Billet Rollers part numbers end with the # “9â€.
I’ve looked at some Failure PIC’s re: these Cast Rollers and there pretty Scary. I’m fortunate that I came across this thread before my Engine was broken in and I attempted to rev 7000rpm.
I am not attempting to BASH Comp CAMS for selling CAST Roller shafts but I was always under the impression that ALL Roller Camshafts were Billet and Comp CAM does NOT emphasize the difference in their product. GM uses Billet Shafts for all their Rollers; WHY not Comp CAMS?
In the mean time, I will have to keep the revs below 6000rpm and keep close watch. I will be pulling the intake off after 5000 miles for inspection and more then likely change out the Cast Mechanical Roller for a Billet. When I order the Billet Roller and springs it will probably be from Lunati or Crower rather then put my trust in Comp CAMS again.
If you have Experience with tComp CAMS CAST Roller Camshafts or are in the same position as I am and feel deceived Please POST, as I require allot of convincing if I am to keep this camshaft.
What pisses me off the most about this finding is that I have put out money for a Forged Crank, Forged Rods and Pistons Plus Severe Duty Valves and to unknowingly install a NON BILLET Camshaft is upsetting to say the least especially after discussing the engine build up with a Comp CAMS Tech. I've been building cars for over 35 years and expect bloopers but this is my first experience with Comp CAMS.
This is an example of what I'm getting at: Link at TeamCamaro Forums Re: Flaky Roller CAM: http://www.camaros.net/forums/showthread.php?t=93714
Old May 13, 2010 | 10:56 AM
  #33
Sliding's Avatar
Sliding
Mine are 1349s. I sure hope that I'll have better luck!
My springs are 130lbs closed and have a 390 lbs rate with .560 max. lift that the cam has.
I plan to rev it to 6500-6700 max.
Old May 31, 2010 | 05:59 AM
  #34
Sliding's Avatar
Sliding
Update......
I'm finished with intake manifold (superram) porting:
Old May 31, 2010 | 02:03 PM
  #35
surfer93's Avatar
surfer93
Surprised no one asked this, but did you rev a stock engine to 7 grand?
And good luck on your build, thanks for the pics on your build, as I am heading in the same direction, except I am going for a 355.
Old Jun 1, 2010 | 03:28 AM
  #36
Sliding's Avatar
Sliding
Yes, it was stock bottom end, and I revved it to 6300. But it's easy to get
carried away. So I started to rev it to 6500 in first gear and it held up just fine.
On this one occasion I started really hard, had a lot of wheelspin and I let the
engine rev a little bit too high.
On new engine, I'll set the rev limiter to 6500-6700 just to be sure.
Old Jun 1, 2010 | 07:11 AM
  #37
Sliding's Avatar
Sliding
I did some more work.
heads are on
rockers are on and valve lash is adjusted
To Engine rebuild/upgrade project
Old Jun 1, 2010 | 01:30 PM
  #38
MK 82's Avatar
MK 82
Blockman,
Please forgive the hijack but my question is along the same line. I just put a CC 503 cam in my LT4. I didn't change the cam bearings as I thought they would be OK. The engine is out sitting on my stand awating valve springs. I was unaware that there are varying degrees of hardness in cam bearings.
Here is my question. Will the OEM LT4 cam bearings with 40K be alright or should I tear into it and change them while I have it out? The short block is completely assembled.
Eddie
CC 503
Stock LT4 Roller Lifters
CC Ultra Pro mag 1.6 NSA RR
Lift at the valve 0.537
Crane 99893 Dual Springs
P.S. How does one "be careful?"
Old Jun 1, 2010 | 03:38 PM
  #39
MK 82's Avatar
MK 82
Anyone?
Old Jun 1, 2010 | 05:45 PM
  #40
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I will be doing this porting soon. Can you post pictures of the tools you used to get all the way in there?
