running rich
Old Dec 13, 2009 | 09:51 AM
Big Daddy's Vette's Avatar
Big Daddy's Vette
Default running rich
!989 C4 I installed long tube headers. I removed pre cats and middle cat and installed flowmaster 40 series mufflers. The problem I have is it running very rich (LOTS OF SMOKE AND GAS FUMES TO THE POINT THAT YOU CAN NOT START IT IN THE GARAGE)
Old Dec 13, 2009 | 10:28 AM
Road Agent's Avatar
Road Agent
I would say normal with no cats.
Old Dec 13, 2009 | 11:03 AM
WW7's Avatar
WW7
It may be because of the O2 sensor location on your new headers. If you had to move the O2 sensor farther away from the motor it may not be getting hot enough to work properly..If this is the case you either have to move the 02 sensor to the original distance from the head or use a heated O2 sensor.If the above is not the problem you could have a air leak above the 02 sensor that is giving the sensor a false reading causing it to dump more fuel to compensate for the extra air....WW
Old Dec 13, 2009 | 02:44 PM
Big Daddy's Vette
Thanks, I had move the o2 further back. I will look into that.
Old Dec 13, 2009 | 07:49 PM
93 ragtop's Avatar
93 ragtop
do you have a scanner to see if they are working? I think, when they fail, they go rich.
But I would bet on an exhaust leak being the problem.
Old Dec 13, 2009 | 08:29 PM
94vettelover2's Avatar
94vettelover2
Also from what I read & learned on this forum it wouldn't be a bad idea to get a tune.Also your exhaust will not be as clean & will polute more since cats are removed.
To running rich
