Throttle body cleaner.
Old Mar 2, 2002 | 02:31 PM
blk90rdstr's Avatar
blk90rdstr
Default Throttle body cleaner.
What do you suggest i use to clean my throttle body? I plan to remove it but need an idea of what to look for when i go shopping for the cleaner. A soak, a spray, something else? Do i need to disassemble anything on it? Any thing I should do or look at while its off? :confused:
Old Mar 2, 2002 | 02:57 PM
vader86's Avatar
vader86
Default Re: Throttle body cleaner. (blk90rdstr)
get some TB cleaner and remove the IAC and clean it as well.
Old Mar 2, 2002 | 03:32 PM
GlockLT4's Avatar
GlockLT4
Default Re: Throttle body cleaner. (vader86)
Throttle Body cleaner ... :D come in 16oz -20oz cans.
Yes, remove all the seonsors before spraying that thing down.
[Modified by Glock'94, 1:32 PM 3/2/2002]
Old Mar 2, 2002 | 03:35 PM
Goody's Avatar
Goody
Default Re: Throttle body cleaner. (Glock'94)
Get some teflon tape for the IAC or some of that plumbers stuff for the threads. Don't need it leaking air.....bad bad bad. Check your vacuum lines too and make sure the ends aren't brittle and cracked. :seeya
To Throttle body cleaner.
